navguy12
Seen. Once its daylight here and I won't get into trouble because I woke someone up, I'll have a closer look...with my reading glasses on!LOL!...I have the same fear before I pry open any lens or trim. Referring to the manual to see what's the correct edge to pry normally helps. Without that guidance, we may end up trying to pry with excessive force at the wrong edge where the hinges are located. If the cover is quite translucent, we sometimes can see through which is the hinge and which is the "clip" side.
And this is what my Amazon.ca shopping cart is shaping up, for the exterior bulbs EXCEPT the headlamps, plus the 33mm interior bulbs:
I "think" this is what I'll get for the headlamps from Amazon.com:
