Honda Service Express Bulletins for 2018 Clarity PHEV
Discussion in 'Clarity' started by AnthonyW, May 31, 2018.
  1. Odobo
    Odobo Active Member
    Just upgrading to a higher resolution screen won't help.... Honda will need to upgrade both camera with resolution match with the higher resolution screen to make it HD, otherwise they can only scale it digitally which won't help resolution, or they will have to give us a option to not show the camera view in full screen.
  3. Atkinson
    Atkinson Active Member
    EV Mode has limits for current draw over time.
    You can use a long slow discharge and stay within limits until the battery is discharged or you can surge for a shorter period of time before demand calls the engine.
    The battery is engineered with only so much discharge rate and then HV gives the battery a breather for another surge.
    Althogh BEV's have much higher allowable loads, their battery management software will throttle the current draw temporarily as necessary.
  4. PHEV Newbie
    PHEV Newbie Well-Known Member
    Clarity fits our lifestyle much better than the Insight. I run several errands each day in town where I can charge between runs so the EV range is perfect. Currently, with the warm weather, electrons cost 1/6 that of gasoline to run (compared to my other car, not really a gas guzzler, which we would be using otherwise). With the Insight, fuel costs would be a bit less than half, still fantastic. There have been posters who don't have access to charging at home. I do think an Insight or Hybrid Accord would work better for them. Heck, there are so many choices out there for fuel efficient, nice to drive cars that it makes no sense to drive a gas guzzler anymore (other than for work needs and towing).
    rickyrsx likes this.
  5. rickyrsx
    rickyrsx Active Member
    I just put gas in for the first time yesterday. I've had the car for one month and one week and I've driven close to 2900 kms before my first fill up!
    PHEV Newbie likes this.
  6. Mart
    Mart New Member
    The dealer battery maintenance is a big deal. This would effect the life of the battery.
  8. AnthonyW
    AnthonyW Well-Known Member
    Attached are all open Service Bulletins.
  9. Atkinson
    "Once the update is completed, the vehicle may take up to one and a half times longer to fully charge."
    What is the core issue that the climate control updates are addressing (besides error messages)?
  10. insightman
    Hopefully, that extended charging time occurs only with EVSEs that previously caused charging to halt completely. Perhaps the update enables the Clarity to overcome a voltage fluctuation by resetting, pausing, then resuming charging. That will be a problem if you're paying for time at a public EVSE.
  11. M.M.
    M.M. Active Member
    My read is that bulletin is pretty clearly saying that it'll charge more slowly with bad power quality, which is an improvement over not charging at all if the power quality is bad. This would not apply to all situations, and it sounds like 1.5 times slower is a worst-case scenario; if it were universal Honda would be opening themselves up to a class-action lawsuit over their (accurate) claims that the car can fully charge in 2.5 hours.
    I do wonder what their definition of bad power quality is, though--low voltage, noise, or both. I also wonder if this is the fix for those situations where the charger registers a fault (my Siemens has twice so far, and apparently some public chargers are much twitchier), or if this is for a situation where the car itself stops the charging rather than the charger.
  13. AnthonyW
    More Cool Stuff:
    VIN, Engine, (Motor), Transmission Numbers, and Paint Codes
    Motor Control System Description
    Block Heater Installation
    Electric Servo Brake System Description - Components
    ET4595, Clarity850, V8Power and 5 others like this.
  14. Steven B
    Steven B Active Member
    Well, just a short time will tell the truth on this one, once people start reporting charge times after applying the update. My view is that the charging system in the Clarity must have a component that was at its design limit with 6.6kW coming in and public EVSEs that pushed that limit and caused the behavior observed early on by @M.M would cause the charger to shut down or hiccup just enough that the EVSE believed it should stop sending electrons. The real mystery here is why this only happened at public charging stations?
  15. KentuckyKen
    I don’t think it has a 6.6 kW/hr limit since my ChargePoint Home routinely charges my Clarity at 7.1 to 7.2 kW/hr with no problems. I’d guess that it’s power fluctuations or noise on public EVSEs (if you forced me to guess).
  16. bakedpatato
    bakedpatato New Member
    I think it's actually a 30a limit, 30a at 220v is 6.6 kW(I guess Honda put 6.6 kw because a lot of public chargers are 220v??) ,30a at 240v is 7.2kW (I have also seen 7.1ish kw)
  17. KentuckyKen
    Thanks, that makes a lot of sense. My CP Home is direct wire with a short run of 8-2 wire so it gets the full 240V (verified by Volt-ohm Meter) so car charges at 7.1 to 7.2 kW/hr.
    Most public EVSEs charge (no pun intended) by the hour so they make more money if they supply the car charger with lower kW/hr.
  18. lordsutch
    lordsutch Member
    Some public EVSEs are on a commercial three-phase supply which gives 208V rather than the more common household split-phase (two 120V legs for a nominal 240V), which may also account for somewhat lower charging rates at those sites.
    Richard_arch74 and KentuckyKen like this.
  19. TimoClarity
    TimoClarity New Member
    I have my Open EVSE wired into the AC breakers since I don't have extra slot and the EVSE can goes up to 50A but the current draw is limited by the car charger to 32A. From minimum battery to full charge take 2.3-2.5 hrs
  20. rickyrsx
    I'm not due to bring in my car for service until another 3 months, should I go in to get these service builtins taken care of before then? I haven't had any real problems with my Clarity other than the weird HV range drop.
  21. dnb
    dnb Active Member
    New clarity owner, where can I check my VIN to see if I need to go in?
    I've checked both in car and from the App and don't see any service reminder/requests.
  22. KentuckyKen
    Unfortunately, there is no way on car, Honda Link app, or any Honda web site to check and see that there are any Open Sefvice Bulletins for our Claritys that I know of.
    You can use your VIN to check for recalls on both Honda and Govt sites but these are only for safety related major issues.
    However, sometimes people report a new update is available (got by buying a subscription to Honda Tech??) and even less often will report they were notified by Honda of one. I’ve never been notified by Honda a depend on this forum to know when to have my dealer install them. One Canadian owner (lorem101, 10/5/18) has posted a notice he got on his Honda Link about a “campaign ID” on the water valve problem.
    Be forewarned, many have reported that their dealer was reluctant to install them or even check do them. And that some flat out lied to keep from doing it by saying it wasn’t for your VIN (when SB said for all VINs) or its already updated (when it wasn’t). It seems you will have a better chance of success if you go in with the Service Bulletin numbers in hand and prepared to counter their BS.
    Fortunately I have a good dealer who couldn’t find them in his computer, but cheerfully looked up the SB #s I gave him and said no problem, we can have it done in an hour.
    I wish Honda had a better system for handling Sevice Bulletin updates.
    Here are some information and posts I’ve gleaned from this forum:
    Service Bulletins:
    6-20-18
    SB 18-069 fixes HV range error
    Applied
    (J-20-18 for Canada)
    7-14-18
    SB 18-079 fixes multiple warning msg
    Not applied by me yet
    18-097 fixes error msgs from public chargers with “dirty” power.
    Reported on 9/25/18 by weave
    By Dmiko on 1/5/18
    EVTC Failure Misdetection: SB 18-089
    HV Range Display: SB 18-091 (seems different from the one others reported)
    Abnormal water temperature reading: SB 18-090. For this one, they ordered a part and said it will take several hours and they would have to disassemble the entire dashboard.
    In my case, the service advisor went to his computer, looked up my car by vin and said: you have 4 product updates available.
    Posted by leop on 10/5/18:
    It appears that the fix for the DTC P26A3 is now a software update mentioned in Service Bulletin 18-089, dated 10/4/2018. I was told that this Service Bulletin supersedes Service Bulletin 18-079. Another Service Bulletin, 18-090, calls for the replacement of the Climate Control Unit. I suspect that this may also be related to problems with the heating water control since the issue corrected is described as coming up when running the heater. These two Service Bulletin updates are to be done at the same time along with a new software update, 18-091, to correct the HV mileage issue. All three (3) Service Bulletins are part of a recall campaign for the affected Clarity automobiles.
    Also
    Yesterday (10/4/2018), my wife had another Multiple Systems Warnings episode. This time I was not there to reset things so I decided to call the dealer and get the fix (TSB 18-079) and well as the HV mileage update (TSB 18-069). The service adviser was surprised at my call as just a few minutes earlier, he was given notice of a recall campaign to fix these (and a couple of other) issues. I had the software updates done this afternoon (10/5/2018) and got paper copies of the four (4) relevant Service Bulletins:
    18-089: EVTC & 3-way Valve software update for DTC's P100C, P0010, and P26A3 (this replaces 18-079)
    18-090: Climate Control Unit Replacement
    18-091: Driver Display Software Update (Mileage) (this replaces 18-069)
    18-096: Warranty Information CD
    The parts were ordered so that the service needed for 18-090 and 18-096 could be done in a future visit.
    All the Service Bulletins are dated 10/4/2018 except for 18-091 which is dated 9/21/2018. The four mentioned Service Bulletins are all lumped together (all mentioned in all Service Bulletins) and the owners all affected vehicles (determined by VIN) will be sent a notification of the campaign.
    Posted by lorem101 on 10/7/18 as received by his Honda Link (Canadian)
    PS: They also installed service bulletins 18-090 and 18-091, and ordered parts for 18-089 and 18-096.
    Hope this is helpful info for you.
  23. toronto_clarity
    toronto_clarity New Member
    Thank you KentuckyKen for summarizing all this. I know this is difficult what would be the best way of getting the Canadian equivalent service bulletin numbers?
    Thanks' in advance to all members here. Great forum!
