What an Engine Air Filter looks like after 83k miles
  • Replies Replies 14
  • Views Views 226
Geor99
I had completely forgotten to change my engine air filter on my 2018 Clarity until today. It's completely toolless and took about 90 seconds from start to finish. It cost $22 at O'Reilly's.
I'd recommend doing it a lot sooner than I did, or your filter will look like mine- see attached pics
Don't forget your cabin air filter, too. I just paid $300 to get a rodent nest cleared from the HVAC system of my seldom-driven Clarity PHEV. I was disappointed I didn't get a photo of the residence.
I was involved with power plant air pollution controls my whole work life. An interesting fact for those interested: The dirtier an air filter gets, the better it filters. The dirt acts as additional filter media. But of course it eventually reaches the point where it chokes the flow and that's NFG and its hard to determine where that point is without instrumentation. Some industrial filtration systems use nothing but the dirt on a metal screen as filtering media, with a system to regularly knock the material off and start over.
That is interesting and makes sense. However, mine looked pretty blocked up and in need of a change:). I did my wife's car as well, which was equally as clogged. I always remember the cabin filter, but I have always forgotten the engine air filter.
I would assume that with the top side looking relatively clean, it's doing a decent filtering job. The dirt pattern is also interesting with a diagonal half looking far more clogged.
And if anyone charges anything above 30 or maybe 40 dollars, definitely do it yourself. Both the engine and cabin filters take about a minute to change and don't require any tools.
How many of those 83k miles were driven with the ICE versus EV mode? I haven't changed the engine filter on either of my Claritys, but most of their miles (65% and 86%) are EV ones.
I'd say it's been 65% ev and 35% gas. I would imagine that air only flows through the filter during gas usage, but I am just assuming. Either way, it was completely clogged with black soot, as shown in the pics. It looks like I was driving through a coal mine for 8 years:)
I'm no expert, but you should probably at least take a look at your filters and decide whether to replace them based on their appearances. They are relatively inexpensive and simple to replace.
Air definitely only flows thru there when the ICE is running.
So, if you have maybe 35k miles on the ICE, that's nothing too crazy. I've seen worse. Good Sanity check just hold the filter up to the sun. If you see plenty of light coming thru, its still ok.
Out of curiousity, did you have a chance to check out your engine air filter? If so, was it as ugly as mine was:) ?
Another thought, if one of these filters doesnt look too bad, does it make sense to clean it to get more life out of them.? Yes, they are not overly expensive; but with a 5 minute clean job; I would bet that one could make this filter look a lot better. Or is this not recommended?
I was thinking that one of those 2 way stick paper rolls that are used to get lint off of clothes might be a quick and easily and productive way to clean these filters?
Just looking at your filter, that looks more like an oily substance, not so much dust and grit. You can smack it on the ground a couple times dirt facing down (I do that every time I check my filters) but in your case, I don't think you will get much off.
Just replace it and enjoy another 85k miles.
I definitely swapped out my old one for a brand new one. Mine was beyond any prayer of cleaning it, I believe. IT had been there for probably a decade counting time being built and sitting at the dealer.
Come to think of it, living in Southern California when I used to live near the MExican border, we often got horrific air; when the wind blew in from the factories and industries and desert fires (very difficult to extinguish so they often let them burn out) on the Mexican side. Some mornings, I could swear that I would smell a spray paint sent in the air.
Before we moved in further north, there were days (often when there were big fires on the mexican side blowing towards us) where I would (sorry if this is disgusting) see black specks in my (whatever is a polite word for a loogie:)) I would also see black, when I would blow my nose.
My filter REALLY demonstrates how bad the air must have been for us for the year that we lived further south than today. IF you zoom in, you can see the oily black whatever it is in the filter. I had that in my respiratory system. It didnt make me sick, to the best of my knowledge at least, but I could see it in the fluids described above.
Then again, the Southern California freeways pumped a lot of exhaust directly into the filters for a couple hours per day, as well:)
Sorry for the slow response; I've been off-grid in Olympic and North Cascades National Parks for the past 2 weeks, and am now in Canada heading towards Banff.
I did check the filter. It wasn't quite as dirty as yours, but I opted to replace it anyway. Given the low replacement cost, I didn't bother trying to clean the old one.
The dirtier an air filter gets, the better it filters...Fact
Yes, and eventually it will filter 100% by completely blocking the airflow:)
Guess I should have added "within reason" as Mr. Towle plainly stated.
Guess I should have added "common sense" should be used based on your situtation.
Guess I should have added "obviously if your environment is dirty" (ie) wildfire smoke then sooner is better.
Guess I should have added "routine mom n pop sedans n mini vans can go much further on a engine air filter then they are told"...its a huge money grab by the auto industry.
Guess I figured common sense would prevail...guess not...so my fault and for that I apologize.
Everyone can change their filters as they see fit. But Mr Towle is 100% correct...he explains it well.
I won't even get into cabin air filters which are not in a closed system and air leaks in from all angles into the car. Let that sleeping dog lie.
Just saying.
Have a great day!
Just saying.
Have a great day!
I was just kidding with you.
