MNSteve
I love it!Here's a new extreme, unfounded, tongue-in-cheek conspiracy theory: Every Clarity PHEV customer is a beta-tester and each car was produced with its own, unique software build.
I don't experience any relationship between SoC and Engine Drive mode. I can get the gear icon to come on at any SoC other than no SoC.
Here's a new extreme, unfounded, tongue-in-cheek conspiracy theory: Every Clarity PHEV customer is a beta-tester and each car was produced with its own, unique software build. Honda is wirelessly gathering data from our cars (we know this to be true). This data helps to determine which software build works best. Because my Clarity hasn't exhibited any problems other than the HV-range overstatement, I feel I was lucky to get one of the good software builds. The question is: Will Honda ever figure out which software build is the best and make it available to all Clarity PHEV customers?
Disclaimer: I made up this wild theory based on no facts whatsoever in an effort to explain the amazingly wide diversity of experiences reported on this forum. Despite the miracle of mass-production, no two cars are alike--even before cars had software. I worked on the line at "Ford's" 50 years ago and saw what can happen to individual cars in the manufacturing process to make them different.
I don't think your WACT is off base. Several of us have posted that we feel that we are beta testing these cars.I don't experience any relationship between SoC and Engine Drive mode. I can get the gear icon to come on at any SoC other than no SoC.
Newbie,
What do you do to get the clutch to engage (at will)?
Does it engage when the RPM's are not close to 36.5 x speed?
I would like to try the same procedure on my Clarity.
So you don't do anything special. Some of the time mine will do that on partial charge, but not on full charge. When mine is engaged, and I'm going up a long hill, it always disengages after a little under a mile of uphill, I assume to start recharging the battery. Since you live in hills does yours disengage like that also?ClarityBill
For the Clarity I drive...for example...when entering a 4-lane highway with a posted speed limit of 45mph...after acceleration to 45 mph...as I decrease throttle to "maintain speed"...the engine clutch engages ~1600 rpms...like clock work. It will stay engaged as long as I don't request more power/RPMs...of say +- 5% of ~1600. If I accelerate/decelerate significantly the clutch disengages...predictably.
Of course, the revs have no choice but to calm down when the Clarity PHEV is in Engine Drive mode because that's the only time when the revs are locked by the clutch and the single-speed gearbox to the car's road speed.My Clarity will go back into gear mode when the 'revs calm down'.
Newbie,
Sounds like your Clarity acts like mine - Looks like we have a failure to communicate.
My gear shows up when I am drawing about 5/16 power on the dash. If the battery can make up the difference (+ or -), the gear mode will stay on while I deviate from 5/16 power: The flexibility to stay in gear mode depends on SOC. Yes, gear mode is possible at any SOC, but more frequent / flexible at 47% with varying drive conditions.
Looks like your 0 EV pictures were at low drive load, so the ICE was able to push the car and charge the battery.
My 'high-rev' is when the generator is charging the battery and pushing the car harder.
My Clarity will go back into gear mode when the 'revs calm down'. It seems like the SOC has to get back to target range (close to HV starting point), and the ICE does not have to charge the battery. The OBDII graphs I posted both showed high RPM's followed by gear mode (flat RPM's).
I drove 'my section of Interstate' again today, and the gear stayed on most of the time.
It signifies the car is in direct drive mode (like a normal car in top gear) rather than using the engine as a generator to power the batteries and the electric motor. It SHOULD be a more efficient mode than the generator mode yielding a few more mpg although that is probably impossible to directly prove. The conditions under which the car decides to switch into this mode seem to vary by many factors yet to be fully understood here.Not being flip here, but what does the gear indicator signify and why do folks care so much about it showing or not?
Newbie,
The end of your drive at 30 - 40 mph would be 'high-rev' in my definition. The RPM's (2K+) are equivalent to synchronous speed at 60 mph, so it is more than 30% over gear drive speed. This is what happens when the battery needs heavy charge during driving. I regularly drive over 70 mph, so 30% over gear speed is loud...
Your drive at 60 mph had the engine shut off a couple times so the battery was maintaining target charge easily. This was probably not a significant incline. Another way to achieve that is to switch out of HV mode (this resets target charge).
When you say "the Clarity I drive exhibits uniform RPMs on the high side (aka no excessive revs)"
Are you saying that your RPM's do not exceed 2500 when you are driving 60 mph going up an extended hill? The graph does show a couple times that look over 3K. There is a reason to be that high, does that mean they are not considered excessive? If you had accelerated over 70 mph these may have gone over 4K, and you would get to be in the "high-rev" world.
My clarity rarely goes over 3K rpm at less than 60 mph, the battery would have to reach an extreme condition. I guess we could say that shows 'uniform RPM's on the high side'. 3K at 60 mph, and 2K at a stop light are noticeable engine noise, and are conditions I consider high-revs.
I'm not sure the RPM patterns are so different for our Clarity's, but the difference is our driving conditions. Our drive speeds are obviously different. What is your ambient temperature?
One condition that I found to give high-revs. Drive EV with a cold ICE. Just before starting a highway on-ramp, shift to HV (sets target charge). The goal is for the battery to be losing charge during the engine warmup time, and results in a large difference between the SOC and the target charge. The engine warmup stays at 1500 rpm, when the warmup time is over, the engine will high-rev. Preferably want to be going over 60 mph at the end of the warmup time. The RPM's come back after charge is restored, and it may even go to gear mode. (This is a procedure I now avoid).
