2002
If it's anything like the Prius which I am more familiar with the friction brakes are used only under 5 mph or in hard stops. I am new to Clarity but expect that even though it's a heavier car the friction brakes are also not used much in normal driving. In fact I posted a previous thread that when I was at the dealer last week test driving my new Clarity there was a ticking noise that turned out to be brake rust that normal stopping wasn't clearing https://www.insideevsforum.com/community/threads/ticking-noise-in-ev.5461/I perceive it that I am using friction brakes more than I would not have previously. Perhaps I'm actually not and its all regen just with a pedal and brake lights - guess as a data nerd I'd be interested to know.
I agree that with traffic around it's safer to slow down at a normal pace. But when no one is behind you a long slow coast is best, because then you are being slowed mainly by the unavoidable and ever present wind resistance, tire friction and mechanical friction, along with a small amount of regen that is provided to add some "normalcy" to the slowdown.
I agree, although maybe it does at certain levels, it's nearly impossible to tell. If it doesn't for regen I think it does for ACC braking. Either way I have always felt there should be a brake light indicator on any car that can automatically turn on the brake lights. That's because the brake lights are a signal to other drivers and I should always know when I am signaling. I know when my turn signals are on, emergency flashers, and reverse lights, for the obvious reason that I am the one who initiated it, but also because for all them there is some kind of indicator. Cars don't have brake light indicators but you already know that even slight pressure on the brake pedal activates the light. But in a car like the Clarity that can activate the brake lights itself I have no idea. Although I do get a "Braking" message on the dash at times and probably that coincides with brake light activation, but I have no way to know if the brake lights come on at other times. I am seriously planning to temporarily rig up a piece of foil or something over a small portion of the third brake light so that I can do a test drive at night and (safely) observe through the rear view mirror when the brake lights come on. Although I don't know of a way to safely activate automatic braking. I know some people make a Don Quixote like charge at a cardboard box in an empty parking lot but I have no intention of doing that.One of the problems with not using much of the brake pedal is not having the brake light turn on to warn the car behind that you are slowing down. Could cause an accident if the person behind is not paying attention.
I wish the brake light would turn on, if you go beyond a certain Regen level.
