ScanGauge II Extended PIDS: Capacity and Specific Energy
  • Thread starter Thread starter AnthonyW
  • Replies Replies 59
  • Views Views 18K
Does that mean that the warranty replacement of less than 36.6 Ah means that our batteries get replaced after they lose ~33% of their original capacity and not the 75% that was mentioned somewhere according to a graph I didn’t understand. This is what I wanted you to verify with the new # I found thanks to Atkinson’s docs. Thanks.
Using your more exact numbers, I still get 36.6Ah/54.6Ah = 67% or 33% loss of capacity to trigger a replacement. Is this right??
Yes, it looks like you are right. What was being referenced before (I think) was a DTC document, that explained how the car calculates and determines battery degradation and activates the DTC and I think the numbers used in that document were dummy numbers to show the calculation and not the exact numbers for our Clarity. So yes I would trust your Pre-Delivery Inspection sheet and your calculations.
Do you mind posting the PDI? Also I am going to look for my PDI that came with the car as I don't think I remember seeing this section.
Cell balancing during charging is an important consideration as variances among cells impact overall pack performance vs theoretical performance based on ideal batteries. So when, exactly, in the charge process, is cell balancing taking place? I think we don't know much about Honda's battery management system and all we can do is infer by reverse engineering from things we do know. One of my concerns about just SOC data is that it is already synthetic, i.e it's already be calculated somehow, batteries don't directly report SOC....
I agree, we don't know how and when the cell balancing is taking place. I saw in some technical document that of the different ways to balance cells, it is easiest to do it towards the end of a full charge session. Right now I can only assume that is where it takes place in our car so each Monday and Thursday, I do a full charge on the free charger at work.
First, thanks to AnthonyW for providing data, it’s a lot of effort. With regards to voltage and SOC, I was looking for li-NMC data because I read somewhere that’s the type used in the Clarity PHEV. I found a recent paper which tested a lg-chem nmc and provided a voltage soc curve. One observation is that nmc provides enough “curve” to use open circuit voltage to approximate SOC. What’s really frustrating though is that they talk about using Open Circuit Voltage ( no load) and then provide curves using charging voltage and discharging voltage. And, yes it makes a difference. For example, using 4.05 volts, measured under charge that’s about 80% SOC and under discharge it’s about 95% SOC. No idea about open circuit measures. So that tells us that we would need to know under what conditions the HBV is being measured in the OBD.
Wayne that’s awesome! I read this exact same paper a week or two ago but haven’t been able to find it since. Thanks for sharing. I did try to record state of charge based on voltage based on the info from that paper but ran into the problems you mentioned. Also in regards to the clarity there is little to no slope in the middle of the curve and dramatic slope on the ends (or so it seems) which confused me until I read the SAE paper I posted yesterday. Honda uses some mechanism with the PCM and DC-DC converter to maintain and boost voltage in the pack. This system is what allows the car to hit speeds of 100 mph on battery power alone. So voltage will go down about 15 points during the first 10% of SOC use and then hover +\- 5 around nominal (311v) for the next 65% usage of SOC and then it falls of a cliff. So our curve looks more like that Tetris piece except for the horizontal section is really long and wide.
Here it is and I also posted it in the thread I made on all the other goodies in this doc.
I didn’t get this at delivery and am having the dealer retrieve it from their off site records storage. I want to see their test of my batteries, both 12v and HV.
Here is the other thread I started on this doc:
https://www.insideevsforum.com/comm...spection-doc-esp-on-battery-replacement.2742/
Okay so we got another one working. It is HBV Hybrid Battery Voltage (Volts). In regards to voltage here is what we know:
-168 cells between packs A and B connected in parallel so basically we have 84 working cells. Source: Design Specs Sheet
-Nominal voltage is 311 volts. Source: Design Specs Sheet
-Max voltage is 352 volts Source: Emergency Response Guide.
-Nominal voltage per cell 3.7 volts. Source: Design Specs Sheet and 311/84=3.70
-Max voltage per cell is 4.19 volts. Source: 352/84
My ScanGuage showed 340 volts after a full charge and ran all the way down to 286 volts before the car turned the ICE on automatically. That would mean that our usable ranges is 4.05 volts to 3.40 volts. Considering that Lithium Nickel Manganese Cobalt Oxide have an operating range of 3.0v to 4.2v (and cut off voltage at 2.5v), this information would suggest that Honda reserves very little buffer at the top and a whole lot at the bottom. This is backed up by the ScanGauge MXS state of charge reading at 96% when the battery is fully charge.
Might also explain why the car has so many unexpected turn on's right after a full charge. With so little buffer at the top, it does what ever it takes not to accept charge any further.
I read this wrong the first time, if the car charges to 4.05 volts per cell, that is very reasonable and the same that the Chevy Volt charges to (which has had a very durable battery so far and also uses NMC chemistry). If the car charged to max voltage, that would be very bad and the batteries would fail like Leafs. Your curve for battery SoC may not be accurate for NMC and might be a discharge curve instead of a charge curve?
Anyway, glancing at this study: http://www.mdpi.com/2313-0105/4/1/11/pdf
A charge voltage of 4.05 is probably between 80-90%, but note that it differs between their two NMC cells and could be different for the Clarity.
My hunch is a simple software update to allow regen to charge 1 or 2% above what the car charges to using the AC charger would have negligible impact on life of cells and allow it to not start the engine so quickly (would still do it on a longer steep hill). Who knows though.
My understanding is that there is a difference between the loss of capacity that will trigger warranty replacement (33%) and the loss of capacity that will trigger a DTC (75%). If you're between those, then you would need to know to take the car into a dealer and get it checked in order to be eligible for replacement under warranty.
I think the Honda SAE article is fascinating, thanks for that AnthonyW. They key new understanding for me is the fact that the electric motor (a voltage controlled device) is powered through a DC-DC inverter off both the battery and the generator. That is, it doesn't matter what the battery voltage is i.e. where it is on the discharge curve, the inverter can boost the voltage to what the motor needs to operate at the desired speed up to 100MPH. The battery chart they show there is KW (power being delivered to motor) vs KWH (power remaining in battery, which we can think of as a proxy for SOC). Because it's showing power delivered to the motor it's not directly related to battery voltage. That flat curve they show is to demonstrate how well they can extract useable power from a range of SOC.
Another way of looking at it is that using the rather less flat NMC voltage/SOC curves, the Honda system inverters compensates for voltage fall off and can deliver a flat looking voltage curve to the motor.
The low end of those curves are also interesting, Honda shows what they call Charge Depletion (which I would like to call EV driving) lasting until about 4 KWH remaining on the battery. That's about 24% SOC. That should be the point when the ICE turns on automatically, which is at about 2 bars on the displayed energy meter (10% if I recall). In real terms then, actual SOC (rather than what the meter or Hondalink displays) that Honda wants to operate the battery at ranges between ~20% to ~95% SOC. Mapping that to 0-100% on a meter means the thing is non-linear, but then we expected that looking at the battery voltage curves.
One final thing I want to say, is that battery chemistry is the "secret sauce" for EV manufacturers. I think Honda has developed a drivetrain/powerplant able to extract the most usable amount of power while preserving cycle times and battery life. Future improvements will be in battery chemistry. Which is why it was interesting to see Honda, this month, sign on to GM's battery development technology. To date, Honda is buying battery's and seemingly not engaged in battery design, unlike Tesla, GM and BMW to name a few. Partnering with GM will allow Honda access to some secret sauce and keep pace with developments.
Here is the status of the X-Gauges. As mentioned before, James at ScanGauge, sends me codes to try and I report back whether the car accepts/acknowledges the request or not (anything other than a blank), and if not blank what that value is. Its a slow process. We were able to get a few in the same data bank up and running pretty quickly, but the others are proving to be difficult. He has been on vacation the last two weeks so no progress has been made.
Next on my list is to observe HVC - HV Battery Current (Amps) which shows current usage in real time. I plan on recording values when charging from a level I and II charger, how many amps are used at each major acceleration tick mark on the gauge, same for regen tick marks, AC usage at various temperatures and fan speeds and anything else you guys can think of.
Lastly, if you have a ScanGauge already go to the X-Gauge page and try them out even if you don't have the latest software. May still work for you.
Wayne, you are exactly right. The actual SOC (labeled MXS) maxes out at 96% and the ICE turns on at 20%. In HondaLink terms it is 100% to 10%. See picture below, I caught the exact moment the ICE turned on.
  • Like
Reactions: bfd
@bwilson4web has done some efficiency calculations for Prius and appears to be currently working on Teslas. If you can get something similar to what he asks for in this post, arrival of a drag number might be close at hand: https://www.insideevsforum.com/community/threads/tesla-drag-power-analysis.2746/#post-24558
I tagged him in another post to try to get his spreadsheets that we could then manipulate for the Clarity but either he saw it and ignored it or didn't see it.
Right. Read the PDI document and you see this sentence on pg 13: "But unlike earlier vehicles with high-voltage batteries, this vehicle does not set a DTC when the battery pack capacity value has reached the level for battery replacement under warranty." WOW! What's the logic behind that deviation? Hey, yeah, we'll replace the battery at this earlier degradation point, but if the customer never knows the battery's true state, we won't HAVE TO until the DTC pops up.
So this spawns yet another recommendation. It would seem appropriate to include a Battery Pack Capacity Check as part of the Maintenance Minder at some periodic interval (possibly MM Sub Item Code 9 or every 3 yrs). Since we've got Gen 1 models, I'd suggest every Clarity owner request this be done yearly when going in for other maintenance and the results reported: not just "PASS" but actual value (SHALL BE >/= 36.6Ah).
AnthonyW,
Have you tried the other Honda Hybrid xGauges to see what works?
Did the picture come through on post #30? The Excel Table with 5 columns? Those are all the X-Gauges and their current status. Are you asking about the stock gauges such as RPMs, Engine Coolant Temp, MAP...etc? Those work okay and can be pulled by any OBD II reader so I haven’t focused on them.
If a DTC is set, the car will not pass emissions inspection.
So, the car could not legally be on the road (the laws vary by State/County on how long the car can be on the road legally to have the emissions fixed). Fwiw, in many States, after x-months, the car would then need a temporary (5-30 days, varies by State) license/permit to get the car tested again.
Yes, emissions testing can be a massive PITA.
As I understand
, in some States/Counties, that also means that that the State/County has the right to impound the vehicle after ~6 months, if they find it on the road (Calf/SF). WTF????
Imho, they way that Honda is now doing the battery level check is correct.
A DTC should only be set for a bad battery pack only when it's critical to the operation of the vehicle.
Honda has decided that for the Charity, if the battery pack is below X%, then the battery pack has very limited use left in it.
If the battery pack gets to below a specific value (?maybe ~20%?) and stays there, Honda likely has the engine control software decide that it's no longer safe to charge and operate the battery pack because of heat/fire/explosion/death/etc concerns.
When a gen 1 Insight battery packs it in, it no longer charges the 12-volt battery. This problem makes driving the car significantly more difficult.
