@V8Power , I did a limited real world test by allowing my EV to go to 0 and 2 bars until it auto entered HV (it was hard to do as I suffer from IAS [ICE Anxiety Syndrome]).
In 20 miles of mixed city and highway driving with speeds of 35 and 55 and no large hills, everything was fine. The 2 bars never increased and I had no loss of power or high reving although I suspect that on a large enough hill I would have. I could not force myself to test longer, but I suspect that you get a little lower MPG since this limits the full range of power flows the algorithm can select from. This observation might support
@Ray B ‘s theory that even at the 2 bar buffer limit, the algorithm allows a small amount of back and forth charge/discharge but not as much as in a normal/larger SOC and thus you get the angry bees when calling for more than just limited amounts of power for short durations.
As to the buffer question. We have several observations that with a fully depleted battery (0 EV, 2 bars) only 14.1 to 14.4 kW could be added to the state of charge (SOC). So 14.4/ 7kW = 83 to 85% of the battery is allowed to be usable. So we assume that 15 to 17% is the total buffer but we don’t know how it’s apportioned between top and bottom. But one also has to take into consideration that the charging inverter in the car cannot be 100% efficient and so not all of that 14.1 to 14.4 kW actually makes it to the battery pack. You can’t beat the laws of thermodynamics and so some of the kWs measured at the wall by your
EVSE or Killa-Watt meter are lost to inefficiency as heat in the car’s charging inverter. I’ve seen estimates of inefficiency anywhere from 20 to 5% and speculation that Level 2 charges may be more efficient than Level 1. If you assume a around a 90% efficiency, then only 12.5 to 13 kW are allowed to be used. Then that’s a total buffer of 23.5 to 26.5. Holding about 25% of the battery capacity in reserve for battery protection and to mask the unavoidable degradation from the consumer is roughly on par with other EVs and is another indication that our assumptions and speculations are at least in the ball park. Again, what we don’t know is how this assumed, appropriately 25% buffer is split between the top and bottom of the SOC.
Also common sense informs us there must be buffers at top and bottoms since every other large Li-ion battery pack has this and the chemistry/physics dictates that repeated full 100% charge and 100% discharge cycles will destroy any current Li-ion battery no matter what the chemistry or configuration.
Fortunately we have some very intelligent people on the forum and as we build up more observations for them to chew on, we will be able to peel back more of the onion of mystery surrounding our Claritys. Oh what I wouldn’t give to be able to button hole a bunch of Honda engineers and software developers in a locked room for a day!
