bsommerhalder
I get asked about regen braking a lot and best practices re: use of the paddles, so figured to create a post about it and also hear what others have to say.
After a few months with my 2020 (and 50,000km / 30,000 miles), here's how I now regularly use regen braking.
Really the idea is simply to use it like brakes, and like any car, try to reduce how much you use your brakes at all through driving habits.
Let's say you are going down a steep hill. If the speed limit was not a concern and no one was in front of you, the most efficient thing you could do would be to turn off cruise control, set regen to 0, and let the car fall down the hill and pick up momentum, and then just let that momentum take you as far as it can go without having to apply more juice.
But of course, speed limits do matter and we can't just ram the backs of the cars in front of us, so WE get to use regen braking to reduce our speed -- when we need to -- rather than stinky ICE brakes. This same principle applies on a flat road too; no reason to "brake" more than you need to (even if it isn't hurting our brake pads).
- As a rule, I have regen set to 0. I use as much accelerator as I need, and then take foot off the pedal and coast as needed.
- When I need to slow down a bit to adjust my speed, I tap the left-hand paddle once to move up to regen 1. (Often I only need to let it stay on regen 1 for a few seconds, enough time to slow down a bit to correct my speed, then I right-paddle to bring back to regen 0 and simply accelerate / coast again.) If I need to slow down a little quicker, I'll paddle to regen 2 or 3 as needed.
- If I can see I am actually needing to come to an upcoming stop, I will paddle my regen up as I approach my stop, slowing down more and more as I approach the stop, ending at regen 3 and then holding the left-hand paddle down to use regen to come to a complete stop. Then, when stopped, I paddle back down to regen 0, ready to accelerate again.
- Most trips, I do not use the actual brake pedal *at all* -- or if I do it is to react to something that necessitates an immediate stop. (I often consider it a bit of a 'fail' if I have to use the brake pedal! --- I bet my brake pads will last the life of my car)
