Automaker has confirmed BMS update detail.
Upto 80% charging speed is same as before.
But after 80% automatically staring check function of battery..
Estimated checking time is 10~30minute,
if everything is ok then restart charging to 100%!!
PS Not sure 80~100% charging speed..
Most of members said 1~5%!!
Is that the first time after the update you reach the 80% threshold or every single time ? That text does not mention 30 minutes, it just mentions "there are areas where charging does not proceed during monitoring for 10 minutes after 80%".
Exact google translate is
"Battery check logic for 10 minutes at 80% charge added
Due to this, there are areas where charging does not proceed during Monitor 1 (10 minutes).
In test 3 and normal, charging is done at normal speed.
There is a part where the charging time has increased due to the addition of the test logic, but there is no part that limits the available battery capacity§
次 次へ In the event of an abnormality with the test, the warning light will be stopped and the charging will stop / start S
We are once again sorry for the part of the clothes that we did not get enough information in advance as we implemented emergency measures 5
In the near future, we will prepare a Q&A for the number of recall measures and provide reliable guidance.
Thank you for using the website 1:1 inquiry"
