A video has been released that purports to show a Tesla Semi mule. Is it the real thing, though? (Video in link)
...no diesel stacks...
The acceleration is crazy, too.
If you turn up the sound on the video, you can clearly hear a diesel engine starting and idling.
You mean, like this?
it's pretty convincing, especially with the supporting evidence.
Hey if I was driving it would have a Stack.Also, good point. Not every tractor has stacks.
Does this have to do with engine braking? I thought the brakes were air, so maybe a small ICE engine is powering the air compressor?It could certainly be some company's electric mule (Tesla or other); it's possible they haven't yet gotten around to converting the truck brakes to run without an engine takeoff.
I also meant air brakes, but AFAIK the air compressor on ICE trucks is always driven by the ICE; it's possible an initial mule to test the drivetrain onlywould still have the original ICE and the original air brakes; later on of course they'd need to convert the braking system itself.Does this have to do with engine braking? I thought the brakes were air, so maybe a small ICE engine is powering the air compressor?
...it's possible an initial mule to test the drivetrain onlywould still have the original ICE and the original air brakes; later on of course they'd need to convert the braking system itself.
Certainly it's possible, but that's violating the principle of Occam's Razor. The simplest explanation is that this truck isn't a Tesla mule.
...Diesel engines are the opposite, higher speed = more range.
I understand the physics, and I am saying that diesel engines are known to get better mileage/range on the highway than regular gas engines. Furthermore, in any gas engine there is really no efficiency drop off between 25-60 mph. So if a diesel truck was to drive 25mph consistently, it would have a range very similar to a truck driving 60mph. Can the same be said of EV trucks? Is the range of an EV going 25mph different than an EV going 60mph?I suspect that's a misunderstanding of the factors and inefficiencies involved.
As Pushmi-Pullyu said, it's about the wind resistance of the vehicle. The engine may be running at the same efficiency, but you won't go as far at higher speeds. And 60 mph is definitely high enough to make a big difference.I understand the physics, and I am saying that diesel engines are known to get better mileage/range on the highway than regular gas engines. Furthermore, in any gas engine there is really no efficiency drop off between 25-60 mph. So if a diesel truck was to drive 25mph consistently, it would have a range very similar to a truck driving 60mph. Can the same be said of EV trucks? Is the range of an EV going 25mph different than an EV going 60mph?
