Bob,
I think the only good thing is that you have the car on lease and get to return it after a while. My car would turn on after a full charge but the occurrences where few and far between. I suggest this to give you piece of mind. Consider buying this wifi smartplug (2 for 20 bucks):
https://www.amazon.com/Outlet-Compa...=1532228701&sr=8-3&keywords=teckin+smart+plug
Tested it and the power delivery of the 120v 16amp charger that came with the car and even a 120v 20amp charger are well within its safety rating. If you have the stock charger, you will gain 7.00% SOC each hour. If you have a 120v 20amp charger, you will gain 9.85% SOC per hour. These percentages added are during the warm months of the year. Goal is to charge to 90% or 95%. So if you have the stock charger lets use 10.00% for easy math. If you are at 40% SOC when you get home and you want to get to 90% then that is a 50% difference. 50% devided by 10% is 5 hours. Add another 2 hours on top. Either set the schedule to turn on automatically and then turn off 7 hours later or simply plug in the charger, turn on the smart plug (either through the app, or on the plug itself) and set the timer to turn off 7 hours later. Setup of the smart plug is easy and you can control everything from the app. App gives you real time watts, amps and volts and also daily and cumulative kWh used. Once a week charge to 100% so that the BMS can balance the cells. If you don't go above 90% or 95% your ICE should never come on. Manually turn it on once or twice a month to keep everything lubed (if your weekly full charge doesn't make it come on).
Try it out if you want and let me know if you have questions. Think it might give you some peace of mind.
