Carsten Haase
Thats technically tramlining. This is your vehicle’s tendency to follow the contours of the road instead of your steering input as a result of one tire edge riding up on the contour while the other is unloaded. Your car can unexpectedly pull left or right. The vehicle has a tendency to follow the ruts and grooves in the road surface. It can be quite an effort to maintain the directional control of the vehicle in such cases. It is impossible to completely avoid tramlining, all vehicles do it. The tramlining effect is more prominent with performance, wide, and low profile tires than soft flexible sidewall comfort tires.
I've read that BMW drivers often complain of tramlining because most of them come fitted with run-flat tires. The run flat tires have a very stiff sidewall that’s resistant to flex and unable to absorb road shocks. This increases the chances of tramlining.
Well whatever it is, it's a FWD thing. My Miata had almost identical tires (same tire and width) and similar track width/wheelbase and never did anything remotely similar. It's not a unique road issue either, I've driven over the same spot dozens of times with both cars and the MINI yanks the steering every time (with strength proportional to acceleration)
