Looking for real-world EV charging data from U.S. drivers — $5 gift card for contributors
  • Thread starter Thread starter gearup
  • Replies Replies 32
  • Views Views 137
I won’t need one as I already support your goals and objectives. Data and sharing tricks is why I am here. <GRINS>
In 2005, I joined GreenHybid.com because of their excellent database of Prius fill-up data. I was able to gain a lot of early insights that led me to maximize my 2003 and later Prius efficiency. These tricks still work 20 years later with my Tesla.
Thank you so much, Bob. That truly means a lot to me.
Hearing how GreenHybrid helped you 20 years ago gave me goosebumps—that exact spirit of open, real-world data sharing is precisely what I hope GearUp Insights can become for the current generation of EV drivers.
I’ll make sure your Texas and Montgomery trip records are analyzed with the highest level of care. We’re working on the customized charts and report now, and I’ll share the preview with you first via PM before anything goes live.
Deeply appreciate your generosity, encouragement, and leadership in this community!
— Miles
Let me suggest what I think GreenHybrid did. The author integrated a database he had skills as an extension of the forum.
As new insights were gained, he would dump the data, establish a new schema, and reload the old data. The database always had a user entry method to add, update, and get a CVS or parse-able text output. But we could propose new fields that the site manager could add as needed.
To a greater or lessor extent, the Tessie column headers are a good start. But it lacks vehicle information like tire data including tire pressure. Truck stop measured weight. Owner mods for aerodynamics but one caution.
The “how you drive” crowd decided ranking by driver was more important than the engineering metrics (I.e. hypermilers.) This led to schism and active efforts to recruit GreenHybrid members to their ‘style’ of driving. That other forum (and advocates) still exist and I recommend ‘be aware’ but not dependent.
Let me suggests a VIN variant be used to identify data contributions … not usernames. VIN has the ability to characterize the exact make and model and often trim. Perhaps omit the last 5 characters to keep the unique vehicle anonymous.
Keeping with your mission, EV chargers might be an associated database. For example, I have used Tesla portable, 3d party portables, JuiceBox, and open EVSE (my favorite if obscure.) Also primarily SuperChargers since 2019 and other, non-Tesla chargers with mixed results (often expensive and reliability issues.)
Sorry, I am overloading you with specs that parallel my private quests. My Tesla is far from stock and cross country driving tricks not always intuitive.
Quick update for everyone who followed or helped with the Founding 10 cohort—we hit all 10 approved sessions and just published the full write-up:
A few numbers that stood out from the stored billing records:
- Across all 10 sessions (269.892 kWh total, $95.49 billed), the weighted average was $0.354/kWh.
- Once we separated out the two $0 promotional sessions, the 8 paid sessions averaged $0.500/kWh (+41.2% higher).
- Paid rates in this small sample ranged from $0.292/kWh (ChargePoint, MO) to $0.638/kWh (Applegreen, NY)—a 2.18x spread.
We also documented exact field-level evidence limits for every single submission so readers can see what the screenshots confirm vs. what was participant-reported.
Special thanks to @bwilson4web as well—we've also published a separate invoice breakdown of his 15-session Tesla Supercharger trip here:
Appreciate everyone's help getting this first dataset off the ground!
Yeah, checking prices at every nearby station one by one is a pain, especially when they can change depending on the time of day.
Right now I'm collecting actual charging costs from drivers rather than trying to build a live pricing map. I'd like to start by comparing what people really paid across different networks.
I'm curious though — would a map showing recently reported prices still be useful to you, even if they weren't updated in real time?
Yes, very useful. Especially when plotting a trip and charging. Often I find that there are several choices for chargers and I wish I had any info at all about pricing/time of day/session fees at a particular charging site to rule it out or include it in possible sites to charge at depending on how low the battery has gotten. I plan my charging before I leave home and if on a longer trip, bookmark sites I might use, and any data on price would help that alot. Once in awhile, someone on plugshare will point out that a charger is very expensive, sometimes there is actual pricing at time of day, but often not.
.29 to .63 is a huge difference if you're charging from 10 to 80 percent.
If you use ChargeHub app, it tells you the price for each charging station on the map.
That's the exact gap we kept running into with PlugShare too—great for finding plugs, hit-or-miss on what you actually pay. On a 419-mile Alabama trip we just broke down, three Tesla stops ran $0.43–$0.44/kWh while one EVgo stop on the same day came out to $0.688/kWh (58% higher). Seeing the actual billing numbers side by side is what we're trying to build out next: What a 419-Mile Tesla Road Trip Reveals About Real-World Charging Costs | GearUp Insights
I will just say it again. ChargeHub has this all on their App. It is up to date, easy to use and costs nothing. It even tells you how many chargers are at each station, what kind, how many are available and the price. It is all one really needs.
I'm in Portland and mostly charge at home, but road trips up to Seattle and down I-5 are where I hit this. Planning around price differences like the EVgo gap you mentioned is tough when apps disagree or show stale rates. For home charging I went hardwired to avoid the plug upgrade, and I'm weighing the ChargePoint Home Flex against a cheaper unit — ChargePoint Home Flex Hardwired J1772 Level 2 EV Charger Review — but I'm unsure whether its app pricing or TOU scheduling is worth the premium for us. Curious what others here actually pay per kWh on their home plans.
Does your EV offer a charge-scheduling option that could take the place of the EVSE app?
In SE Michigan, during the peak months (between June and September), charging between 3 PM and 7 PM costs me 24.13¢/kWh and 18.44¢/kWh at other times. I plug-in at 7 PM and my MINI's tiny 32.6 kWh battery is always fully charged by morning. So I don't need an automatic scheduling option.
I just have a mechanical timer set from 11:00pm to 7:00am and take advantage of the low rates.
