I am due for my first oil change vary soon. I am going to be sending my oil in for analysis before the change. At below 17 gallons of gas burned there is no way I can need an oil change. If the results show I don't need an oil change, I can ask honda to repay it or start gathering data showing it dosen't work for a small claims court case. Ultimately, this feature not working affects the value of the car and the cost of maintaining it and it also affects the warranties on Hondas side. This is something that can be easily proved to be not functioning as advertised and they base warranty work on it. So this affects the value of the warranty.
Just wondering if you had the results from the oil analysis that you could share to the forum? Curious as my first oil change showing now 7713 miles and 48 gallons of gas (probably just over 2100 HV miles).
