No problem.
Unfortunately it looks like a problem has cropped up for me. A couple days after I installed the wiring harness, the brake lights on the trailer started to be on continuously.
Upon checking, I found that power was being delivered continuously (14V) to the right/left turn signal plugs on the vehicle whether the vehicle was on or off. It was obviously working normally when we first installed it and when we initially hooked up the brand new utility trailer (Stirling from Canadian Tire). On the trailer, the brake lights stay on continuously and the right turn doesn't blink but I don't suspect it is the trailer. I have checked the Ground is OK on the KONA and there does not seem to be a visual short anywhere.
Need to confirm with multimeter. Has anyone else who has done the wiring have any issues? I also noticed while searching there have been recalls related to factory installed wiring harnesses and trailer wiring in the past.
2015 Sonatas -
bad wiring harness recall
2009-2011 Hyundai Veracrus and Kia Sorento -
Wire Harness and Converter water issue recall
2016 Hyundai Tucson -
trailer turn signal wiring recall
The Tucson recall is similar though not the same to what I am experiencing: "In the affected vehicles, when the vehicle's engine is running and the brake lights are illuminated, if the turn signal is activated, the trailer turn signal lights will either turn off or remain continuously illuminated (not flash)"
Any advice greatly appreciated.
