I just purchased a 2018 Honda Clarity PHEV Touring vehicle .
Great car after 350 miles but I am seeing only 38 EV miles on a full charge, not the 48 claimed .
Are others seeing this as well?
EVs are most efficient at low speeds. Tesla says their cars are most efficient at 23 mph and the range drops some every mph above that. It's probably similar for the Clarity. Most of my EV driving is in town. In the summer, a 16.5 mile loop I do a couple of times per day consistently uses 19% of the battery (as indicated by the Hondalink app). If the battery measurement is accurate, that's an 86 mile range under such conditions. Not sure if it can actually get that but I once drove 70 miles on a single charge around town and the battery still had range left when I got home! Now that it's winter, my range has dropped significantly, especially when I heat the cabin, even modestly.Have you been using the heater? Lots of highway?
The estimates are based on how you are driving. Driving slowly in the City will give you more range than at highway speeds (especially above 70). In NY, I'm regularly getting 50+ miles, even in cool weather, as long as I only use the heated seats. Using the electric heater (which is what happens when you use heat without the engine) will reduce your range by an amazing amount.
This has been covered in lots of other threads
I hesitate to say that it is a claimed range of 48 miles all electric, it is the label required by the EPA, and during EPA testing the car will see 0-47 miles all electric under similar conditions, if you were to repeat the EPA test. The 0 meaning the engine can start if it needs to, in practice it doesn't randomly start very often. As with car gas mileage, real world results will vary.I just purchased a 2018 Honda Clarity PHEV Touring vehicle .
BTW, some people may not like the way the Clarity looks but it is designed to be very aerodynamic to maximize EV range and HV mileage. The Outlander PHEV, which is less aerodynamic, only provides 22 mile EPA EV range even though its battery is more than 2/3 the size of the Clarity's. Also, its gas mileage is much worse than the Clarity in hybrid mode.
Yep, normal. I had posted about the same thing a while back. Car originally reflected 47+ miles EV and then after some time driving it in colder temps, it dropped down to the high 30s. We just drove down to AZ for Christmas and now EV mileage shows 48+ after a full charge.
I would suspect that you will see 25 to 75 mile all electric range most of the time. You might see 25 in sub 0 F (-18 C) weather and you might get 75 driving 25 mph around an oval track. Typically you should see mid 30s (winter/cold/high speed) to low 50s (summer/mild weather).
Your 38 mile EV range probably means it is either colder or you are driving at highway speeds, or maybe both. For reference, my Wife's Clarity recently showed 34 miles EV range. It has been around 35 F and was driving 75 mph on the Interstate for the previous trip.
(I had several edits above)
Thank you for your reply!
I wonder if there is a simple function for temperature affecting EV mileage and if it is linear or logarithmic?
Sure, US06 (SFTP) is the more aggressive test, and I think they combine that with the older less aggressive test (FTP):Thank you for the reply!
Do you know where I would find the EPA test specifications?
I doubt is was limited; more likely that's what they had data for from the initial testing of the old Accord and they weren't going to refresh one to test it (it would need to factory fresh condition for the test to be accurate))You can see that someone at Honda decided 100 mph was fast enough for the Clarity, but was the 2014 Accord Plug-In limited to a top speed of just 75 mph?
