Alex0913
Came on 4 times in 3 miles just now.
Your car is clearly doing something unusual, do you have a way out of your lease? Or this, as annoying as it is, is not a deal breaker for you?
Or maybe Bob is playing us and keeps posting to this thread just to collect the forum trophy points. I expect his status to soon change from 'active member' to 'master of the forum.'Your car is clearly doing something unusual, do you have a way out of your lease? Or this, as annoying as it is, is not a deal breaker for you?
This is happening too many times to be a fluke.
I just can't imagine why the engine would fire up.
I could understand the generator spinning the engine with fuel off to dump charge.
Volt manual says othewise.View attachment 2019
Why do you guys assume when the engine start it has to consume fuel? The car can simply turn on the starter and let the engine crank without injecting any fuel to it to burn off excess energyI believe that the 4,000 lb the Clarity PHEV needs to offer more powerful pseudo engine braking (including paddle-initiated regen) than could be provided by the lighter Accord Hybrid's method of using the starter motor/generator to spin the unfueled engine to burn off excess regen energy when the battery is fully charged.
If I'm wrong I would welcome the actual explanation, but my theory is that the Clarity PHEV uses the starter motor/generator in reverse, to slow the running engine and burn off excess energy faster than the Accord Hybrid can. The curious downside is that the super-efficient Clarity PHEV--against character--uses fuel to dispose of excess electricity generated during pseudo engine braking.
Good point, but given the previous HV miles bug I wouldn't totally trust that piece of code either, also the HV mileage include the EV mileage too so maybe the code consider that as a waste hence lower the HV mileage when it should be adding to the EV mileage normally.Then why does the HV mileage go down? That should only happen if fuel is being burned.
