Are you able to experience repeatable results with your experiment? Does the engine always start if you touch the left paddle at the top of the hill after you top off your battery?I topped off my battery yesterday and then went down a long hill. I only used the foot brake. During the entire time the energy meter did not dip into the green at all, nor did the engine start. Basically when the battery is full, avoid the regen paddles until you use up some battery.
It was a joke. Look at it closely.Is that a new error code showing up on your car?
Hi Bob,Simple question: When the ICE comes on if it is not using gasoline why does the HV range go down?
Do you know for certain that gasoline is NOT being used?
I don't know for certain but Alex on Autos is one of the most thorough car reviewers out there so it's likely that his information is coming directly from Honda. If gas does inject into the engine, either the engine will fire up (that would be counterproductive) or if it doesn't ignite, the unburned gasoline will pollute and cause all sorts of problems like ruining the engine oil and potentially causing backfiring in the exhaust system when the ICE next fires up. Neither scenario is likely. The fuel injection is computer controlled so it is a simple thing for the gas to be shut off.Do you know for certain that gasoline is NOT being used?
So it must be burning gasoline which still begs the question why? The Chevy Volt only does this rarely. Same technology.I don't know for certain but Alex on Autos is one of the most thorough car reviewers out there so it's likely that his information is coming directly from Honda. If gas does inject into the engine, either the engine will fire up (that would be counterproductive) or if it doesn't ignite, the unburned gasoline will pollute and cause all sorts of problems like ruining the engine oil and potentially causing backfiring in the exhaust system when the ICE next fires up. Neither scenario is likely. The fuel injection is computer controlled so it is a simple thing for the gas to be shut off.
Even if the HV numbers are off the fact that there is a decrease is evidence that gasoline is being burned And then there is the obvious engine noise.My house is on the hill. At the morning when I going down the hill with the fully charged battery, if I don't apply the brake from beginning, the ICE will come on and I can see the white smoke in the rear of my car via the mirror so I believe the the ICE did burn gasoline.
