Sindhu Rumpler
This video has a great step by step video for how to unplug the speaker.
Note that doing this and driving the car violates a federal road safety regulation and would put you at risk of a ticket.
As for the BATT_COOL_EXV system, I recently took a long trip and did a fair amount of fast charging en route. On 50 kW or higher chargers after a point I did hear a fan kick in that immediately cut off when the car throttled down the charge rate to around 24 kWh at 70% full. I suspect this circuit controls this fan and it is important to keep your battery safe during fast charging at higher rates. Maybe it kicks in too driving long distances on a hot day, but I am unsure if I would have noticed it at highway speeds.
So, you can pull that fuse by YMMV.
I also wonder if unplugging the speaker as shown in the video above ALSO disables that fan. I don't know if it would, but it is strange that there are four leads going into the speaker. Why would it need any more than two (though if the electronics that generate the signal for the speaker are also in the module, that could be the explanation. Would have to disassemble that module to know)? Does the battery fan system run out of that module too? IS it daisy chained with the fan system so breaking the circuit will disable the fan? Might need to do some fast charging experiments to see....
don't just pull the fuse , it is a real liability then. Avoid a ticket, instead get a 50$ fuse bypass switch on Amazon. this allows you to switch it off only when the you have to drive backwards , then you can switch it back on! nothing illegal!!
