How reliable is the Hondalink app for you?
  • Thread starter Thread starter Mark W
  • Replies Replies 114
  • Views Views 22K
I don't know which cellular vendor it is using so I can't deduce how strong the cellular signal is in the garage
You can Check the cellular signal in your garage by observing the dash display at shutdown. The first thing it shows you is TCU and an antenna symbol with the cellular signal strength and underneath is your car’s charge timer state.
(TCU stand for Telematics Control Unit)
I’m not having any problems connecting, even when I was on vacation for 10 days and two states away, but I have a strong signal in my garage. As long as both your phone and car can get a good cellular signal to Honda’s servers, it should connect just fine.
Just be aware that Honda tries to conserve bandwidth and cost by not having it report in real time. For example, odometer doesn’t always update if there is no change and the battery SOC only updates every 15%.
You can however force an update by sending data such as find my car or changing settings. Considering that we get this for free, it’s an equitable trade off IMHO.
Based on what I'm seeing (attached file) the signal couldn't be much better. And of course when I tested turning on climate just now, it worked perfectly. Thank you for fixing my problem.
As you can see, my Timer says "Off". what is my "car's charge time state" and how do I change it from "off"? (Sorry to hijack the thread.)
No prob. Was supposed to say “timer state”. The off just tells you you have not set up any charging schedule on the car. Useful to verify so you don’t have any problems public charging or like me that you’re free to set up a charging schedule on your home EVSE which is easier to me. You can change this in settings to take advantage of lower rates if offered by your utility.
Looks like you have 3 of 5 bars signal strength which one would expect would be enough. I’ve got 4 of 5. If you have continued problems connecting, you might try resetting the head unit (hold down audio button) or reinstalling the phone app. Also, make sure you have the correct app for the Clarity, but if you are connecting sometimes you probably have the right one. As a last resort you could try disconnecting the negative battery terminal, but then you will lose settings and range estimates will start from scratch. Let us know your progress.
The app works perfect for me. I will caveat that by saying I have only had my car for a week and haven't tried preconditioning yet since i only plug in with a level 1 charger at home. So really the only thing i use it for is to monitor the charge level.
I plug my car into the free level 2 charger in my parking garage, and i want to be a good charging station patron and move my car when its done charging, so i constantly monitor the app to see when it is done charging. I was disappointed that i wasn't getting the "Charge Complete" notifications that everyone else was mentioning on here. I searched through the entire app and couldn't find anything. It only just clicked with me before writing this post that when i first downloaded the app i chose to "Not Send Notifications", as i do with every app i download (i hate getting a million notifications). Went in and switched that on for the HondaLink app, so i'm excited to see that "Charge Complete" notification in 30 mins when it should be done.
you can precondition car with level 1 charger as long as charging is done( i.e. like a cold morning) and the cord is still attached. It will precondition and then start charging to keep full.
This is certainly useful info! Thanks!!
I have only been able to get this to work once. And that was with the car’s key fob. Is there a special way to manually turn “on” the car, while connected to a level 1 evse, and charging is complete from overnight but still plugged in?
You haven't. The fob only turns on charging, not climate.
Charging does not need to be done (100%). You can PC the car even when you are not 100%, you just need to turn off charging first then you can turn on PC. IF the charge cord is still plugged in, charging will start after PC is ON. Charging stop automatically if PC is turn off (manually or after 30 minutes)
Use the app to turn it on
I used it for scheduled PC for the first time this morning and it worked like a charm. Fantastic feature.
I totally forgot that. I even looked at my fob before posting and blindly ignored that fan button... :(
I'm pretty sure you need to lock from the fob before remote "start" will work, but perhaps I'm just carrying that over from the previous two SUVs we owned.
New to the forum so i dont know if this has already been covered but My other family vehicle is the 2018 suburban and the chevy app is the only reason i know the honda app is terrible.. i can start the truck in minutes... send directions to navigation instantly and lock and unlock the doors...
with the honda app it has taken 15-20 minutes to get directions sent to vehicle... awful
Compare the price.
Have used this daily to record and monitor KWh usage and also pre-heat the car daily with the temperatures well below freezing. Nice to get into a warm car. The warmup does draw from the EVSE units though.
Yep, I can confirm that. Heating is VERY slow, though. Mine took about 20 minutes to go from 32 degrees to 42 inside temp this morning.
