I was impressed that this has a clipper creek board for a fraction of the cost. However, a bit confused as to why it has a nema 14-30 plug. The website implies that you should use a 30 amp breaker. Other 16amp chargers suggest a 20amp breaker as more than sufficient. Why the discrepancy? I'm assuming that a 30 amp circuit probably requires a different gauge wire. At any rate, I have a 20 amp breaker and am not sure this unit would work. Looks better than the Chinese stuff, however, and it is UL certified.
I thought you had your issue resolved and were hiring an electrician to pull a 40 amp circuit?
Anywho, with regards to your breaker question. Any electrician installing a 30 amp plug is required to run 10 gauge wire by code, and will normally then install a 30 amp breaker by common practice (smaller than 30 would also be OK by code). So this is surely the reason they recommend a 30 amp breaker...it's simply the proper size for the circuit with the plug they utilized. Doesn't make any difference what amperage the charger is actually going to pull. It's about wiring the house properly to meet code to prevent fire risk, and nuisance breaker trips, for ANYTHING ELSE that might be plugged into that outlet. Some day that charger will be unplugged and thrown away, and some future owner of the home might plug in a dryer or welder or larger car charger or something instead that will overwhelm the circuit.
People continually confuse portable charger amperage requirements with home wiring code requirements. Because portable chargers can be removed by simply unplugging them, the HOUSE must always be wired properly with the plug. So a 30 amp plug REQUIRES a full 30 amp circuit with properly sized wiring. Even if the intended use for the plug is for a 16 amp, or even a 4 amp product today.
Even though it's a 16 amp charger, this particular charger you were referring to has a 14-30 for nothing for than convenience -- it's a dryer plug outlet commonly found in many garages. So it can be used in many homes and locations easily, without any cost of hiring an electrician. Unplug your dryer, and plug this in.
I think a better question is...why didn't they make it a 24 amp charger? That would make a lot more sense given the plug they installed and the circuits it is intended to run on. I find it a little odd they chose 16 amps, unless they were looking at a price point for marketing purporses, or got a heck of a deal on the 16 amp circuitry and it would have just cost too much and hurt their profits to make it 24.
