unless your really need to rapidly (2.5 hrs) recharge during the day no need for it. stick with 110 charging overnight. you save a bundle between not buying a new charger and extra cost of 220 vs 110 line additionwhere and which ev level 2 charger should I buy for my new honda clarity touring?
if you can return the charger you might consider sticking with 120 line. waiting 2 1/2 hrs for just 50 miles in a pinch doesn't seem worth so much money when you can just use a little gas on rare occasions.In Ottawa canada i am looking to install 240V circuit for chargepoint plugin 32 amp charger. To add the circuit to my panel, the 1 quote i have so far is $1700+tax which seems excessive (~ 6ft linear distance from electrical panel to garage wall, maybe 12-20ft copper run:.
For any ontarions does this seem reasonable or is it at least 50% over expectations. To be clear: the chargepoint is already purchased: $1700 is just for the circuit run to the garage +nema outlet.
Thank you.
That seems high if you already have 200 amp sevice and all you need is a 40 amp breaker and a 10’ft run to a receptacle. Get more quotes and don’t mention the expensive words solar and electric vehicle.I am planning on getting solar, and I asked one of the companies the cost of installing a 240v circuit, was quoted ~$650. w/10 ft copper run and conduit. This is in Northern California.
Sent from my Nexus 6P using Inside EVs mobile app
