JyChevyVolt
You need to set the parking brake and close the door to initiate a charge on Charge Point chargers. Otherwise, Charge Point will throw out a charging fault.
Very weird. I've charged our Hyundai Sonata PHEV multiple times at ChargePoint locations and never had to set the parking brake. I even did it with my Tesla S and never had to set its parking brake either. I'm very curious to try it on the Clarity now.Commercial charger. Happened twice. Called Charge Point and the CS instructed me to close door and set parking brake.
EVGO do not require setting the parking brake. Only happens on Charge Point.
Will throw in my 2 cents. Last night stopped at a public charge point station that I used to frequent with my Ford CMax Energi without issue. Plugged in my new Clarity PHEV. Faulted after one minute. Moved car to the next station and it did the same thing again but this time turned on the check engine (malfunction) light. Will have to take it in to find out what happened. Drove home normally and plugged into my 240V Juice box with no problems.
There really isn’t anything in the J1772 protocol that deals with the door or parking brake. I have an OpenEVSE and can change settings and monitor the interaction with the car. I’ll do some testing and see if I can figure out what’s happening.
I have the same problem charging in 2 of 3 charge point stations near my home. In another thread some users reported the same problem with charge point stations. Setting the break or closing the doors didn't help.You need to set the parking brake and close the door to initiate a charge on Charge Point chargers. Otherwise, Charge Point will throw out a charging fault.
Schedule charging off too?I have the same problem charging in 2 of 3 charge point stations near my home. In another thread some users reported the same problem with charge point stations. Setting the break or closing the doors didn't help.
Sent from my Moto G (5) Plus using Inside EVs mobile app
