EV Range highs and lows
According to the GoM, I'm on track to 357 miles range.. Started out at 100% charge this time. 5.9 mi/kwh seems to be the best efficiency that I can come up with..
According to the GoM, I'm on track to 357 miles range.. Started out at 100% charge this time. 5.9 mi/kwh seems to be the best efficiency that I can come up with..View attachment 5409
That's awesome. I've been averaging between 4.8 and 5.3 miles/kwh. Just recently charged to 88% and the GOM is predicting a 298 mile range. Now if I can just figure out how to get back and forth to work by going downhill both ways ;-)
It looks like you're on track for 416, no?
208 (@50%)X2=416 (100%) Why 360?
Based on the GoM... Based on my energy consumption it would be 5.9 mi/kwh x 64 kwh (usable battery capacity) = 377.6 miles. Charge is at 47%, not 50%...
Based on GoM, 365.5 miles range and based on my mi/kwh - it's 377.6 miles range.
I'm travelling at reasonable speeds but I absolutely minimize AC use.. I only turn it on once it becomes unbearable in the car.. I'm just doing that when I try to maximize range.. Once I finish this charge, I'll start running the AC a lot more.. I just want to see what is possible in fairly normal driving conditions on my daily commute.
Looks like we may have to start a 350 Mile Club!
Update on my current charge. Finally broke 6.0 mi/kwh. GOM has adjusted and now shows a total range (miles driven + miles range) of 381.3 miles. That seems to be very accurate based on my usage. 6.0 mi/kwh x 64 kwh = 384 miles.. GoM is withing 2.7 miles of that.
I can see that ICE owners try to hypermile as it saves expensive gas, but I can’t understand why so many people are hypermiling with their Konas evs. The savings in costs are minimal compared to gas. Just drive the car and enjoy it!! Achieving 500km (300 miles) just means the car was driven at city speeds mostly or too slow on highway. Not really meaningful to others.
For me, this is just a test on what ia possible in real life traffic and not on a circular track at a constant slow speed. My test is at my actual commute, going about 5 mph slower than I usually would and not using the AC. Once the test is completed, I will go back to my normal driving habits. It is good to know what range is possible in case of having to reach a charger on a road trip.
I'm well over 300 miles on my current charge.. Should be over 360 miles when I connect to the charger later today.. GoM adjusted to around 390 miles of range. Miles/kwh is up to 6.1 as I drove 2 mph slower than before as I want to make sure that I will make it home after work today.
I'm well over 300 miles on my current charge.. Should be over 360 miles when I connect to the charger later today.. GoM adjusted to around 390 miles of range. Miles/kwh is up to 6.1 as I drove 2 mph slower than before as I want to make sure that I will make it home after work today.View attachment 5431
Works out to Avg. 35 mph (56 kph), must be all city driving and on flat roads, am I right?
Nope, that was on my daily commute. 22 miles on Highway each way at 56 to 61 mph and some city traffic to drive to lunch every day. Stop and go.. Regeneration set to level 3. I baraly ever use my brakes. Just hit 358.8 miles.. I'm in Florida, so all flat roads.. Virtually no AC use..
Well ive hit the 300 mile club, i've had my car for almost 4 weeks and every day it impresses me more and more. my driving is a mix of highway and city, with fair bit of flat but a few good bits of hilly area's. if im mathing right that's like 323 miles and 5.4 miles/kw. its kinda fun trying to see how good you can be on the throttle to be super efficient but not be that guy that is slowing everyone down
View attachment 5439 View attachment 5440
Congratulations!
Make sure to post here so we can keep track of these:
https://www.insideevsforum.com/community/threads/kona-ev-300-mile-club.6098/
17 degrees C , where is your location?
i'm in new brunswick, canada. was a great night to go for a drive tomorrow is suppose to go to 38 degrees C
Wow, that's hotter than here in Florida.. We hit up to 37 C on a hot day. Average however is 34 to 35 from June to September and 29 to 32 in October..
its normally not that bad, usually june/july its 25-30 but weve been getting some pretty hot weather the past few days it was 27 today so i was quite happy with the 17 tonight
