That kind of heat should max out the range, keep an eye on the TMS if you do go for a drive just for informative purposesi'm in new brunswick, canada. was a great night to go for a drive tomorrow is suppose to go to 38 degrees C
idunno if it was cooler i wouldn't run the ac as much. all my driving has been with ac on to 20 degrees C with a mix 75/25 drivers only id estimate and set to auto for fan speedThat kind of heat should max out the range, keep an eye on the TMS if you do go for a drive just for informative purposes
27/17 sounda like November in Florida.. that's perfect weather for me.. Florida is great from October to May, but June to September is very hot, humid and rainy.. I wish I could live in a cooler place during the summer months..its normally not that bad, usually june/july its 25-30 but weve been getting some pretty hot weather the past few days it was 27 today so i was quite happy with the 17 tonight
Yes, I've resigned myself to never getting the super-high 550+ numbers some are reporting. I just don't do much city driving which contributes in a big way to their efficiency. I'm 95% highway 90kmph to 110 with heat/ AC almost all the time.The most ive gotten is 458 but i drive it like my other vehicles except i dont use the climate.
I think my numbers are not getting higher cuz i mostly do highway driving.
A lot of people have been discussing EV Range, I was thinking it might be nice to see what others get for estimates when fully charged. My goal is 300 miles / 482 km, and driving pretty conservatively, I've managed to get to 297 miles on a full charge.
My current driving score is 98% economical and 2% normal. I live in a fairly hilly area, and the temps have been very moderate, between 40-70. I think the hills hurt a bit, obviously you can regen coming down the other side but I think it uses more power to get up the hill than you ever get back, so generally flat driving would likely be better, but I'm just guessing.
Here's my screen grab...
Can only vouch for the -5 C, the heat pump keeps the cabin warm with no real noticeable range loss. The car came charged at 100% and showed 436 km on the gauge. Since the warmer weather occurred the range has increased to over 500 km (according to the car).Range and cabin heat in an eastern Canadian winter
Any info would be appreciated as I am considering buying a Kona EV for life in Quebec! This would be our households ONLY vehicle.
At these temperatures below:
Is the cabin heat adequate in winter for a middle aged person with a tendency for cold feet?
And how much range is lost in winter with full winter tires and cabin heat on?
at -5 C.
at -10
at -15
at -20
at -25
As a skier, could I possibly get from Montreal to Le Massif in Charlevoix - about 360 km - at 100 kph mostly flattish freeway at -10 C, outside average temp, with winter tires and cabin heat on? Or am I dreaming? Presumably a top up would be required somewhere before Quebec City...
How much do snowy roads, uphill climbs and wind affect winter range?
Some comments on the web indicate anywhere from 25 to 50 percent range loss in a Canadian winter depending on conditions.
After a high of 503km my GOM range keeps creeping lower. 493 to 490 and now 488. A bit discouraging (though I know it's really not significant). I'm intrigued to see if, once fall comes, I'll bounce back to my May/June highs when I can drive again without climate.
What climate are we talking, A/C I hope, should be a small increase in consumption . 503 to 488 is not bad.After a high of 503km my GOM range keeps creeping lower. 493 to 490 and now 488. A bit discouraging (though I know it's really not significant). I'm intrigued to see if, once fall comes, I'll bounce back to my May/June highs when I can drive again without climate.
Yes. It's AC. The projected range loss when I use it is about 30km off the total projected range. The GOM range is the one that has been ticking downward, undoubtedly because it's noting my continual AC use and is incorporating it into its guesswork. Once I can turn that off in cooler weather I'm hoping the GOM will rethink its math.What climate are we talking, A/C I hope, should be a small increase in consumption . 503 to 488 is not bad.
My range in winter, minus 35°C ,was high 300s with heat and winter tires.Can only vouch for the -5 C, the heat pump keeps the cabin warm with no real noticeable range loss. The car came charged at 100% and showed 436 km on the gauge. Since the warmer weather occurred the range has increased to over 500 km (according to the car).
In colder weather losses due to resistive cabin heat would increase range loss. And then there is the winter tire losses , battery pack heat , cold temp etc- my guess would be 35% .
Maybe someone from Ontario or Quebec could chime in and give more accurate results. I think the 360 km might be a bit tough
I'm going to guess lots of city driving. Average speed less than 50. That's an outrageous number!Completed a full charge the other day, and my GOM was reading 367 mi. Highest I've seen so far.
