EV-only operation question
jazdean
Suppose I were to continue to drive my 2018 clarity PHEV locally and just stopped putting gas in the tank. Eventually, I would burn all the gas and it would run only on the battery, albeit at reduced power. With the vehicle software allow me to run it like that indefinitely? Has anybody tried this?
Once the tank is actually empty, a "power system failure" warning will come up on the display, and it will beep at you constantly until you refill the tank. I know of no way to turn off that warning. But, if you just turn it off and back on again, and avoid hitting the accelerator hard enough that it tries to turn on the gas... Also, it'll probably complain about not being able to do its regular "maintenance" gas cycles.
That sounds like a really terrible idea. Not only for proper operation, but it would ruin the resale value, which is still considerable - about $10K - $12K. My engine came on the other day while in EV mode, and while I initially didn't like it, I have learned to trust the Honda engineers who have made this car so reliable.
Plus, you never really know when you may need to use the engine - an emergency may come up, and you need to drive hundreds of miles. I understand you are just spitballing here ... but why bother to even go there?
You will run out of gas and the car will stop driving. Even if you keep it in EV mode, if you accelerate hard, it will kick on the engine.
There is no way to LOCK it in EV mode. Hence the car having to have gas no matter way.
Not to mention an instant emergency, when you need maximum acceleration, which the motor can deliver only with help from the engine's power contribution.
This idea is asinine. Fuel systems are designed to have fuel in them, and engines need to be run to avoid sizing up.
If you want an EV, get an EV, don't ruin the propulsion system of a PHEV.
If i don't use ev for a long time, eventually my gas motor will fire up and run for 2 or 3 minutes. I have intentionally drove until I ran out of gas but immediately switched back to ev. The car ran fine in ev for around 5 miles to get to next gas station. Just had low fuel light on. You could potentially keep around 1 gallon in the tank and run on ev for several months.
When you said you ran out of gas, did the gas engine actually turn off from no gas? How did you lock the engine in the on position? HV Charge?
The default mode is ev when you turn on the car and the gas will not come on until the battery is used up unless you push the gas pedal past the detent you can feel. I selected hv on a road trip and wanted to run out of gas to see how far the car would travel after the fuel light came on. When it started sputtering I turned off hv mode and the ran on electric to the next gas station. So in ev mode the gas will not come on unless you run out of battery or you drive aggressively and floor it (push past the detent)
Honda Clarity has a pressurized fuel system. It's the reason we have to wait when we press the open fuel lid button. This design seals the gas in to help avoid evaporation and blocks outside oxygen and moisture from coming in. The online query seemed to think that 12 months is a good limit. But you can pick the increment you like. I think I'd choose ~6mo's and burn the gas and replace it, whether it needs it or not. My natural patterns sometimes leaves the same gas in the tank untouched for 2 months at a time, but I do burn gas from time to time for longer trips, so I've never let it sit more than 2 months. And lately, as my car has aged and my EV range has naturally gone down, I do burn more gas in hybrid mode than I initially did.
There is a great way to fix your Clarity. Sell it and buy an EV. You will then have real "Clarity". ;)
It's all about the right tool for the job. I love my all-electric MINI Cooper SE, but it's EPA range is just 110 miles. I just returned from a fun drive down a curvy riverside road to the cider mill. The MINI was the perfect car for that task.
OTOH, my Clarity is the perfect car for long trips into places where EV charging stations are few and far between. Around town, my Clarity uses the same amount of gasoline as my MINI. One year I didn't visit a gas station even once. However, right after achieving that milestone, I drove with the engine running to use up its 7-gallon tankful of old gasoline.
Someday, there will be so many EV charging stations that PHEVs' advantage of fuel flexibility won't matter. Hopefully, when that day comes, competition will lower the exhorbitant cost of public charging (compared to home charging). Going to the lowest-price charging station won't carry the same product-quality concerns that buying the cheapest gasoline does, but the lines will be longer.
It was a hypothetical question. I've yet to see convincing guidance that it couldn't operate with limited range, albeit at reduced max power. For myself, I love doing 90% of driving in EV mode and having a very efficient HV mode kick in when needed. Charging at home costs about $0.13/kw which equates to about 5¢ per mile. That's versus 13¢ per mile in HV mode. Charging at public stations erases that benefit, but even home charging doesn't save money, after paying the $225 a year in extra fees at registration renewal in WA state. But the convenience of avoiding gas stations, quiet operation, and the benefits of not polluting are worth it. (Well, less pollution, since about 50% of our power comes from non polluting sources).
What is the $225.00 for?
Washington charges battery-electric vehicles (and plug-ins with at least 30 miles of electric range) $225 a year in extra fees at registration renewal. It's split into a $150 electric vehicle fee (to compensate for not paying gas taxes at the pump that support road maintenance etc) and a $75 transportation electrification fee (to support expansion of EV infrastructure). This is on top of normal tab fees and taxes. Hybrids pay $75 a year. Electric motorcycles pay $30.
In Canada, it's a more fair system. We pay tire tax that supposedly pays for road maintenance.
My state, Michigan, charges an annual registration surcharge of $267 for EVs and $113 for plug-in hybrid electric vehicles (PHEVs), on top of regular registration fees.
EVs weighing more than 8,000 lbs. (we're talking about you, the 9,000-lb. GMC Hummer EV) pay a $367 surcharge. If there was a PHEV over that weight (I don't believe there is one), its owner would pay a surcharge of $183.
