- Anyone having the engine randomly turning on while on EV and not accelerating pass the click:
I'm not sure about this. Usually, when the engine comes on I either have no EV miles left or am in HV mode. I suspect that maybe it has happened while in EV, but can't be sure.
- Before you purchased, where you ever told by dealerships or sales people that the car would do this (and also go into high revs randomly):
No. The sales person didn't know much about the car. I had done research and knew MUCH more about the car than the salesperson did. I knew that the engine revs would not match with the accelerator pressure like most cars, but was NOT expecting the small number of cases where the HIGH revving occurs. That is bothersome.
- Would you have purchased the vehicle knowing it would do these: Yes. I certainly don't enjoy the engine revving, but I understand (mostly) why it happens. But the high revving happens so infrequently that it doesn't bother me much.
Yannick - You're obviously is a tough spot. The revving is not acceptable to you. Do the explanations that you have read about why it happens help at all? I would think it might be a little better if you understand that what is happening is happening for a reason, and is not just a straight defect. That's not to say that it will solve the issue for you. If the revving still bothers you, then no explanation helps. Many things add up to how the driving experience is for someone, and it's not enjoyable driving a car does things you are not happy with. I hope you can get something worked out with them.
This brings up a tough issue regarding cars that qualify for big government rebates. Normally, in a situation like this, I would think a dealer would want to handle the situation with a customer that is not satisfied with their car by doing a refund, or swapping out another model, with it being more straight forward. The problem with these cars, and any that qualify for a $7,500 federal rebate, (and in some states an additional rebate) is that once a car is purchased, even if it's returned, it is not then eligible for the next purchaser to get that rebate. So that car immediately loses at least $7,500 of value from the transaction.
