I suppose something like this for the Clarity will surface eventually and may provide more insight into actuals: https://insideevs.com/see-how-to-install-leaf-spy-pro-on-2018-nissan-leaf/
Being an engineer, this got way longer than I intended, so here's the executive summary/tl;dr version:
Given Clarity has 20 bars to represent about 12 kwh of power, they are probably around 1/2 to 2/3 of a kwh each. Meaning it keeps maybe a 1 kwh or 1.3 kwh buffer. They probably have a little more beyond that they don't use to protect the pack. This means maybe around 2 kwh on the bottom, 12 kwh usable, and 3 kwh on the top?
I can't say for sure whether every bar represents the same amount, but I can say with certainty that it isn't linear over the full available charge range, since the first bar doesn't disappear until below 90% according to the app (which appears to be correct). If it was linear, each bar would be around 5%, give or take, so either there is an invisible chunk at the top that isn't represented by the bars, or the size of each varies.Perhaps on the Clarity every bar represents an equal amount, as common sense would suggest. But I wouldn't just assume it's so without evidence.
While yes, there are no doubt varying reserves at both ends on every vehicle, there's a fair degree of certainty that the general design is similar because lithium-ion battery chemistry and endurance is well understood, so the bottom-line advice I came up with is going to be pretty much true of any vehicle that doesn't fully charge or discharge its battery.Unfortunately, in practice, that advice will still needs some interpretation for individual models of PEVs (Plug-in EVs), because they probably use different percentages of reserve on the "top" and "bottom', and the gauges of different PEVs almost certainly don't report SoC (State of Charge), or permanent loss, in the same way.
Like the Joker said about Batman, “Where does he get all those wonderful toys?”
Seriously, where are you finding all this great Clarity info? Did you have to subscribe to Honda Express Service?
We could haul one of theseDoesn't regenerative braking affect this?
I also trust Honda has the overcharging thing taken care of as it is such a basic thing.
The only thing in our control is....do we charge every time we are in the driveway? I have been told yes by volt owners. Now I am not so happy with that answer.
We can send stuff to mars but figuring out perfect charging methods for consumer goods is still alluding us.
haha I have little doubt one of my "friends"We could haul one of these
Your friend has shared a link to a Home Depot product they think you would be interested in seeing.
8,000-Watt Dual Fuel Powered Electric Start Portable Generator
https://www.homedepot.com/p/205635157
...only our Canadian comrades get the battery heating.
DTC P144A (78): HV Battery Pack Deterioration (High Severity)
Take a look at the attached DTC. I am having a hard time interpreting the chart. I have some thoughts but would like to hear what you guys think.
