That SAE paper probably clues into why the engine runs so much in extreme cold, as it is heating the battery with engine coolant as I was guessing. If car is parked in attached garage it takes very cold days of around 0F or less ambient to start the engine. Looking at that paper the trigger is 32 F battery temp which triggers it, which is about right for my garage temperature (garage is maybe 25 F on those cold days, but battery is insulated and takes time to drop after charging, etc).
The paper also shows the worst charging efficiency at 88% for 240V (assuming all energy lost is in the form of heat, maybe that isn't a valid assumption for the battery), which is better than my pessimistic self gives it (I usually say 80%). It shows max heat rejection as 860 W for Battery, DC-DC, and Charger. It also shows most of the losses in the charger, I figured it would be the battery.
The Clarity only is 311 V Nominal (168 cells in 84s2p format, so this puts it at a pack size of 12.4 kWh usable, which is more inline with what I expected if it is 20 Ah for each cell usable, of 27.3 Ah rated, which would be ~17 kWh at 311 V).
I love all these technical papers you are dragging up specific for the Clarity, keep up the great work
