Car Scanner is a cross platform iOS/Android alternative that works better than Torque Pro. I just discovered it today. Torque Pro has a bug, in the way it handles the large messages that the Clarity outputs, and wraps the data. So it can't extract all of the the other info out of the PID that we're using to get the battery capacity.
https://www.carscanner.info/
Another thing that's nice is that even the free version works to get the battery capacity.
Here is a screen shot of it displaying the battery capacity:
Here's how to input the PID into Car Scanner:
Excellent work! Car scanner did all it was supposed to - but the BAFX still doesn't work - buffer overflow...
Just got email from Amazon delivery that the 'proper' ELM is supposed to be delivered in the next 3 hours... not bad for ordering yesterday evening!
Then I'll see if I can get a reading
Seems like if i select “honda hybrid” in car scanner setting, more HV related pids will appear. Unfortunately my elm adapter have a short buffer, so I can not read most of them.
Assuming I get a measurement close or lower to what my dealer provided I think will validate your work....thanks again!
I forgot to mention.. not all of Car Scanner's Honda/Acura PIDs work on the Clarity. I'm surprised that Honda uses different PIDs for different cars, but maybe it has to do w/ the parts vendors that they're using on each car.Yes, I was surprised that it was pre-loaded with some useful EV Power train PIDs
If anyone gets a system up and running in the Los Angeles area in the next 4-6 weeks, I’d volunteer my car for diagnosis. Just had a dealer measure it at 49.9aH yesterday.
After that it’s off to Oregon for good.
The board won't let me PM you. Send me a PM if you want me to take a reading from your Clarity
If you are comparing Car Scanner to Torque, there is an important technical issue that we must identify.Car Scanner looks nice and I'm going to try using it, but it does seem to have some differences from Torque Pro
Does anyone know why I have to always replug the VGate adapter? Do you have to do this as well? It always works fine once it's connected
Thanks for the clarification on why VGate requires replugging all the time!Yes... @lincomatic and I have discussed this one at length.
What is happening here is that the adapter (in it's infinite wisdom) powers down after 30 minutes of "inactivity". The theory is that this will allow you to keep the adapter connected without worrying about battery drain. The trouble is that "inactivity" is measured by activity on the CAN bus. The adapter will power itself back up when CAN activity resumes. In most cases this works out well because the next time the vehicle is 'started', the CAN activity resumes.
The Clarity however, does NOT have any activity on the CAN bus during normal operation of the vehicle. It is only when you interact with it with Car Scanner, or similar that the CAN bus is alive.
This sucks, but the only way we have found is to physically unplug, and replug the device after it has shut itself down. Note - It will also shut down after 30 minutes even if the car remains on (as long as there are no CAN interactions). We have not been able to think of a good way around this. The 12V pin on the OBD2 connector is always alive.
You don't really want a device that is always on because that would be a constant drain on the battery.
The only thing I can think of that might improve this would be to cut the 12V wire from the vehicle and re-wire it to a 12V source that turns off when the vehicle is off. This way, at least starting the vehicle will always turn on the device. It does NOT prevent shutdown if the vehicle is on for an extended period while driving (with no CAN traffic). Of course, this alters the OBD2 standard (albeit just a little).
I thought CAN bus is used for most of the electronic signals in a car, is this not true?
I wish our cars had a simple menu where we can limit max battery level.
