Yep. You should be just fine. The Prius Prime uses a J1772 connector just like the Clarity so that will work.Hi, new (used Clarity owner here, but when i bought the car, it was missing the 120V charge cable, a friend has an extra one from his old Prius prime but before I take it, does anyone know if it can be used on a Clarity?
Thanks!
We have a Chrysler Pacifica PHEV and it too has an OEM EVSE that will run on 240V. I keep it at my shop plugged in exclusively to 240.In fact, the Prius Prime has a evse (Electric Vehicle Service Equipment) that is identical to the one in the Clarity. Made for worldwide use by Panasonic, it will run on either 120v or 240v power. Use mine exclusively on 240v power; it will charge empty to full in about 5.5 hours.
Nissan would disagree. CHAdeMo is the other, not-as-common, connector.To the extent of my knowledge, all PHEV and BEV share the same J1772 standard connector except for Tesla.
The LEAF has a J1772.Nissan would disagree. CHAdeMO is the other, not-as-common, connector.
Thanks, I just learned something today.The LEAF has a J1772.
The CHAdeMO is used only for DC Fast Charging and all vehicles that use this standard will also have a J1772 for AC charging (Outltander PHEV, i-MiEV, Soul EV, etc)
I was going to say that my cheapo Zencar level 2 portable charger was sold to me as compatible with Fiat 500e, Chevy Volt, BMWi series Toyota Prius plug-in, Ford Fusion, C-Max and... NIssan Leaf! But DucRider draw firstNissan would disagree. CHAdeMO is the other, not-as-common, connector.
The thing to keep in mind is that the “charger” is not really a charger. It’s simply a smart switch which supplies either 120 VAC or 240 VAC to the car. The charging circuitry in the car itself is what determines how much current to pull. This is why pretty much any “charger” with a J1772 plug will work with any car that has a J1772 receptacle.I was going to say that my cheapo Zencar level 2 portable charger was sold to me as compatible with Fiat 500e, Chevy Volt, BMWi series Toyota Prius plug-in, Ford Fusion, C-Max and... NIssan Leaf! But DucRider draw first. BTW, they didn't mention the Clarity as compatible but it's the same J1772 thing, or at least has been working for me for a year.
Thanks for the clarification!The thing to keep in mind is that the “charger” is not really a charger. It’s simply a smart switch which supplies either 120 VAC or 240 VAC to the car. The charging circuitry in the car itself is what determines how much current to pull. This is why pretty much any “charger” with a J1772 plug will work with any car that has a J1772 receptacle.
That’s very interesting. Makes you wonder if somewhere along the way Honda was contemplating a larger battery.Here's an interesting charging conundrum that results from all EVs being designed to protect their batteries by slowing the charging rate as their batteries approach a full charge.
The MINI Cooper SE has a 50 kW onboard charger vs the 100 kW charger of the Honda e, but the Honda e doesn't charge even close to twice as fast. In fact, both cars charge from 0-80% in about the same time (30 minutes for the Honda e's 36.5 kWh battery vs 35 minutes for the SE's 32.6 kWh battery).
Even though the Honda e can draw 100 kW, it does so for a very short time before it starts tapering off the charge to something closer to the SE's 50 kW charging rate. If they both had 60 kWh batteries, the charging time difference would be much greater because the Honda e could maintain the full 100 kW charging rate for much longer before approaching a full charge and tapering off the charging rate.
Like the Honda e, the Clarity Electric's 50 kW charger tapers off pretty quickly due to the car's relatively small (for a BEV) 25.5 kWh battery, so it also takes 30 minutes to charge from 0-80% on a DC Fast Charge box.
Of course, unlike a PHEV driver, no BEV driver ever willingly drives their car down to a 0% charge.
The situation you present is a lot more complicated than above, and there also several misconceptions and misstated facts.Here's an interesting charging conundrum that results from all EVs being designed to protect their batteries by slowing the charging rate as their batteries approach a full charge.
How different BMS systems handle fast charging is a bit of a black art, and a bit of a dance between performance and battery health.@DucRider, I'm learning a lot. What part of a BEV handles DC charging and limits the DC charging rate? Would the Clarity Electric have charged any faster if it accepted 100 kW (or an equivalent Amp/Volt combo) like the Honda e?
Do manufacturers and DC Fast-Charge kiosks list the charging rate in kW because listing Volts and Amps separately would be too confusing and more difficult to compare? Isn't the charging fee linked to the number of kW delivered?
Was I correct that the reason the Honda e doesn't charge much faster is because the tapering off of the car's charging rate begins early in the charge cycle to preserve the small battery?
Regarding the MINI's battery, MINI couldn't fit the i3's Samsung battery into the Cooper S, so that car uses a more advanced CATL battery of about the same capacity. MINI claims the CATL battery is less prone to cold-weather range-reduction than the Samsung battery.
Finally, when I read in 2019 that the upcoming MINI Electric would charge at 11kW on AC, I ran out and bought an 11kW EVSE to replace the one I was using to charge the Clarity. Later, the big "Doh!" when I found out 11kW charging requires a 3-phase AC EVSE and a non-J1772 connector. Clearly "future-proofing" requires a better understanding of the future than I had.
