Another BMS recall for the Kona
In order to evaluate the condition of our cells and the effectiveness of our BMS in re-balancing the cells I would like to be able to see the change in individual cell voltages while the BMS is performing its magic.
Anybody have a method to do this without having to crack open the modules and attach measurement wiring to each cell?
Additionally, if someone has collected real data that could be used as a comparison benchmark, that would be extremely helpful.
Car Scanner does a great job doing that.
Thanks. I assume you are using Car Scanner to monitor your cells.
Have you ever observed/recorded the balancing in progress?
Only when charging and observation only.
On the 2024/25 pack, the cells are 1P, not 3P as previous years, so the voltage differential between them was easy to monitor.
When I first got the Kona in 2025 the GOM range was 240 miles and that seemed accurate.
I had the BMS update in Aug 2026 but hadn't done a 100% AC charge until yesterday.
The GOM was 330 miles!
And I did a 251 mile journey half 50mph half 70mph, and had 73 miles left and it was at 5miles/kWh.
Which ties in with the 330 miles GOM.
Very happy with that frugality!
Have they altered the battery top and-or bottom buffers ?
Wow .. That's Great.. I just had that campaign done last week. Have yet to charge to 100% to see the effect. My 2020 maxed out at 310 miles the 1st year I had it.. My recent charging to 100% tends to max out at 280 miles GOM. I don't usually charge to 100% as I put low miles on it.
So I finally charged to 100% following the BMS campaign. Very happy. at 100% I now get a GOM of 315 miles. I was topping out at 280 prior to this campaign. This is similar to what happened in 2023 for Campaign 9A4 whereby I got 323 miles after that one - I was only getting 250 prior to THAT one.
I wonder How that all happens
After latest BMS campaign ( 61D004 ) my BMS SW Boot version was bumped to 7220 . I don't know what it was before, but according to KiwiME's post on previous page I suspect was 6910 .
