V8Power
I wanted to hardwire my dashcam so I needed to get access under the dashboard especially under the centre section right under the climate controls to run wires and hide a cigarette lighter socket. I figured out how to do it without breaking anything and thought I'd share how I did it and what it looks like with the covers removed. The 2 removeable covers on the driver & passenger sides just pull off without tools. You just pull directly away from the console on the edge nearest the seats and the 3 clips release, with the panel about an inch away from the console, gently pull the panel towards the seat about another inch to remove it from the connector in the back. Be careful not pull the panel away from the console too much once the clips release or you might bend and break the connector on the rear that is closest to the firewall. The two sides slip into a mating part but beware that the left and right rear connections are different. Now you have full access.
While under the dashboard with the panels removed, I noticed few cool things.
-The GO pedal's mechanism looks very digital, high quality and the pedal itself has a hollow structure to it.
-the dashboard's structure is made of cool looking aluminum - love it!
-the hidden components all have a high quality look & feel with attention to detail. The passenger side rear clip that inserts into a slot has some felt tape wrapped around it I suspect to ensure a squeak & rattle free drive, well done Honda!
