Sounds like rotor rust. I get that sound a lot in normally humid conditions and it does't take much time here - 2 days. You hear the clunk as the pads disengage from the rotor.I also have not driven mine much in the past month, perhaps 40 miles total in that time. The only thing I've noticed is a clunking sound when I shift into reverse from my driveway after not driving the car for a week. Doesn't match anything I've seen people complain about, but have had happen it a couple times now.
They get a small film of rust on the surface (like everything else around here by the ocean and wet environment) but clean off rapidly with a couple of brake applications. They look similar to these:I'm in a desert climate where rust is very slow to form. Are you saying you get rust on the rotors of your car? If so, that means they didn't FNC treat them to prevent corrosion. GM uses a special metal treatment process on the Bolt EV rotors to prevent them from rusting because they know many owners will never use the brakes while driving in one-pedal-mode.
If you use the brakes occasionally, that thin layer of rust should get rubbed off automatically.
