This is a continuation of some of my observations
farther back, when
all I had was a voltmeter to try and observe what was happening with
the 12V system voltage under various operating conditions. Now that
I can observe battery current and DC/DC converter current separately
via OBD2, I have a little more info, as long as OBD2 isn't lying to
me. For reference on monitoring via OBD2, see
this thread that got
split off when another thread got too messy; for this post, just
accept it as a black box that the figures can be read.
DC/DC or "LDC" as it's called, i.e. the equivalent of the alternator,
can only produce current one way, or nothing. The 12V battery itself
can have positive and negative currents as it charges and discharges.
I'm still studying this because even though Hyundai USA has basically
blown me off about my "voltage too high for AGM" case, I still want
to understand what's going on and perhaps figure out if there *is*
some weird subtlety in how the LDC running conditions are engineered.
In particular, yesterday was quite warm and I saw a recurrence of
the highly variable conditions I noted upthread here. While it was
cold, though, the rail sat solidly at 14.8V and as high as 15 at
times, possibly in an attempt to match lead-acid charging scenarios
where applied voltage *is* supposed to be slightly higher in cold
weather. But still not that high. I have no idea where the threshold
temperature is for changing behavior yet, of course.
It was a little above 50F yesterday, and I was on a drive long enough
to get the 12V fully charged so it really didn't want any more current
into it. In that state, regardless of rail voltage, that current
measures 0 or maybe -1 amp [charging is negative]. The LDC baseline
powering the car is still 9 - 10 amps, pretty much directly running the
electronics, and never varies much. Here are the voltages I noted:
* 14.8 sitting in Park, 12V battery current still just about 0
* 13.4 sitting in Neutral ; voltage slowly drifts down to that
* 13.4 rolling in Neutral
* 13.4 driving normally, accelerating or steady-state
* 14.8 *any* regen, even the tiny trickle in regen-0 mode
* 14.3 under any of the above, with *certain* large loads turned on
That last entry is the really weird one, not that it isn't all weird in
general. Lighting the headlights makes the LDC drift down to a more
appropriate voltage albeit still a bit high for float, and stay there
REGARDLESS of driving condition. So does turning on the rear defroster,
which is maybe a 200 - 300 watt heater. However, the seat heaters
have no effect, even if they're both turned on high. The fan doesn't
change anything either, even on full blast. It wasn't raining; I didn't
think to try the wipers. What are other typical large 12V loads if
you haven't installed that monster "bassmobile" stereo? Externally
applied loads at the battery, even large ones, don't seem to make
any difference either.
It's not a dependence on what is served through the "intelligent power
switch" module, either. The headlights are, but the rear defrost has
its own relay and comes straight off the "multi-fuse" on a 40A tap.
My guess is that *certain* loads generate traffic on a CANbus to tell
the LDC to move to that intermediate voltage, for some reason, perhaps
an alternate to the 13.8V state to compensate for some high loads that
might stay on for extended times while driving?
When the voltage drifts down, 12V battery current is still 0 and the
LDC output current is about the same. With the current sensor on the
negative side of the battery and the voltage-sense terminal on the
positive, the LDC *must* be fully aware of its condition. The battery
settles back to a reasonable "just freshly charged" resting voltage,
and the LDC follows along but doesn't let it actually supply any of
its own current for running the car. Why being in Park or having regen
going into the main pack matters to this setup, I can't imagine, or
why it wouldn't try to adjust either way if one of those "notable
loads" is on.
If I have one of the still-incandescent visor mirror lights on, I can
see a slow dimming and brightening if I move between D and N while
sitting still. That's an easy "analog" check of what I see on the
little digital voltmeter in the expander box. LED lamps don't really
react to input voltage changes.
I used to observe slightly related behavior in the Prius in warm weather;
its rail voltage would drop ever so slightly going from Park to Drive,
and I could hear a slightly changed note in the inverter coolant pump,
but that's the only change it ever did. All of maybe half a volt, but
apparently by design, still deliberately affected by the driving condition.
I'm firing in all these details mostly to help bootstrap anyone else
who wants to collect more data. I'd love a real answer from Hyundai,
but in the absence of that it would be nice to figure this out from
a "what the F are they thinking" standpoint.
_H*
