I'm about to get the same camera. How was the rear camera install? Also, how much extra wire did you have left for the rear camera and how did you hide them. Pictures would be much appreciated.
This potential problem of damaging it or not being able to reinstall it correctly is why I left it in place and routed the wires past it at its top seam and then down the rubber gasket. This way it’s totally hidden without messing with the A pillar.View attachment 5964 View attachment 5965 Am I thé only one who can’t reinstall the À pillar properly? See the photos.
I think the potential of damaging is very minimal. Taking off the A-pillar is very simple, once you know how things look like inside.This potential problem of damaging it or not being able to reinstall it correctly is why I left it in place and routed the wires past it at its top seam and then down the rubber gasket. This way it’s totally hidden without messing with the A pillar.
Here is that thread with pictures of how to do it without removing the A pillar.
https://www.insideevsforum.com/comm...ires-of-a-windshield-mounted-“dash”-cam.1235/
The problem with approach is that the wire passes in front of the airbag, so it might cause issues if it has to deploy...
If it's any consolation, nmy July build and my cousins May build clarity has the A-pillar that looks like that from the factory. I just pulled it off to hardwire my dashcam and it's seated the same way as yours. It looks to be as a bad mold more than installing incorrectly. Also, it seems I'm missing a green nub/clip for the center clip!The problem with approach is that the wire passes in front of the airbag, so it might cause issues if it has to deploy...
I don’t think my A pillar is broken - it’s just that it seems to be a bit short - I can clip it at the bottom, but then the 2 clips at the top fall under the holes that they are supposed to go in.
Alternatively, when I insert the top 2 clips, the bottom doesn’t reach far enough to go under the dash
Nope, it passes at the top of the A pillar piece that you are removing at the seam between it and the headliner. So it is not in the way of the airbag.
Thanks. I will reinspect immediately and have a trusted mechanic look at it.The airbag is one piece that extends all the way form the dash to the rear seats. Page 9 of the emergency response guide:
https://techinfo.honda.com/rjanisis/pubs/web/AJA07616.pdf
So if you run it across the joint, it would interfere.
Better safe than sorry.
There are people who have not removed their A pillar who say it is short. Mine was manufactured 11/18 and does not seem short, maybe they changed the part at some point? Or maybe there was a bad batch. If it can somehow be confirmed that a newer part will fix it then it is something you will want to get taken care of during the 3yr/36K warranty. OTOH I think I remember someone having the shop change the A pillar but it didn't solve it, but maybe the part they obtained was from an old batch.Just take a picture before and after of you base of your A pillar. I wish I did as the poster above suggested it was manufacturing defect for some models, but now I don’t have the proof![]()
