Esprit1st
or really want bodies of water to be a paler shade of blue.
Finally! I was so annoyed by the old blue!
(End Sarcasm mode)
Regarding the fast chargers, that's probably one thing they got right, most don't work with Kona anyway, I will update the DCFCs that do work thread soon.The update seems to be a dud. I see none of the fast chargers on Vancouver Island, and street/speed info for my area is still out of date. Hardly worth installing unless you're planning to visit Guadalajara or really want bodies of water to be a paler shade of blue.
This is definitely Windows only, no Mac, no Linux, no phones.So do you really need a Windows 7 PC or newer to do this upgrade with or will an android based system work?
That's just plain stupid (not you, the thought that they didn't put the chargers in the map on purposeRegarding the fast chargers, that's probably one thing they got right, most don't work with Kona anyway, I will update the DCFCs that do work thread soon.
For Christ sake!!!This is definitely Windows only, no Mac, no Linux, no phones.
Plugshare comments showing at this location negative for BMW i3 and both Hyundai products including Ionic and Kona only show if you log on to that webpage, otherwise it is limited to the last 5 (most recent) . And no- to this point B.C. Hydro has NOT fixed these machines even with the plugshare input and phoning the B.C.Hydro helpline. As a matter of fact they (B.C.Hydro) have not even returned my call from the teck dept.That's just plain stupid (not you, the thought that they didn't put the chargers in the map on purpose). If there is an issue with the chargers and the charger-supporting company fixes it somehow, then no chargers will be in the map-system. So no! If the chargers are not in the map, they have not been put in there because the company maintaining the map isn't doing their job. It has nothing to do with some chargers not working.
Also, I think that maintaining a thread here is kind of counterproductive. Nobody will comb through threads here in order to find out if a charger is working or not. Tools like PlugShare should be used for that. Put a comment in there so people that might not even be here on this forum are able to get that information. That's what those tools are for and maybe even the responsible parties will find out that way and figure out a way to fix the chargers.
Just my 2 cents ... ;-)
First, congratulations on the successful install and report back. (You are probably the first !)
I would like to comment on your observation of the B.C.hydro station not being loaded as a charging location.
If it's this one:
https://www.plugshare.com/location/152799
are any others of the same type listed in the B.C.Hydro stations thread:
https://insideevsforum.com/community/index.php?threads/bc-hydro-stations.5252/page-2#post-59257
Maybe Hyundai has actually picked up on the fact that these machines are not compatible and if that's the case what DCFC locations are listed on the island ( and the rest of B.C.) that ARE compatible?
( just a few will do)
maybe they will. Not holding my breath.So why don't they just send a new SD card to start with to avoid this type of problem![]()
Not totally uselessGlad to hear the maps are still useless, just like they were before. I am curious if they really believe people will pay for an update after the 3 years of free usage. If the information was current it would be a great tool but this is a joke. I'm curious if I'll see updates here in the US but I doubt it.
Very disappointed in that part of the software.
I know, right? Like, why do they need this "device number" when you're already registered with your VIN? Your VIN is literally one of a kind.Ooh man, typical developer problems. Why don't they just use the same page and deliver different content by registered VIN number? Ooh wait, that would be too easy and straight forward. [emoji23]
I had noticed that for some reason, I received two emails acknowledging that I had downloaded the maps, and as I mentioned before, they were being shipped, which I am sure is not true, but I saw there was two different order numbers. The latest one, within minutes of the other one, was the order number shown on the web site, and the number I entered into the map download app. It was the one that could not be authorized. I still haven't heard back from Hyundai, but I had a thought - maybe I could make the download app use the other (slightly older) order number. So I put in that order number, and the app said the maps have already been download, but the install button was active, so I thought that it can't get any worse, so I put in the sd card and clicked install. As before, it took around 30 minutes, to get to the scarey 'get authorization code' button, I clicked and it went off, and low and hold, it was authorized, and the program finished. the sd card was ejected. Took it to the car, and maybe because I had already tried to install and got to the not authorized message, the install this time took only a minute and the map was update!!. So I have navigation again, no thanks to Hyundai. The web site still shows the other order number, but it doesn't matter anymore.I think the main problem is the Canadian Hyundai site is using a modified version of the USA site and software. They have neglected to fully amend the software to properly download and install the maps. Some of this might have happened on the weekend when apparently they "fixed" a software problem. The app that downloads and installs the map still has links to the USA site, and this caused me some problems (the site looks exactly the same, but Canadian username and passwords won't work). It may have even downloaded a US version of the map, and maybe that is why the Canadian site will not authorize the map, I don't know, but they sure do have problems. I followed directions exactly, and used my Canadian order number and device ID. In the meantime, google maps and car play!
