AnthonyW
I am pretty confident that I have discovered why the ICE turns on after a full charge and other situations such as going down a large hill. While waiting for flight this past weekend, I decided to take a look at Honda patents. I stumbled upon "US10011270B2 Apparatus and method of controlling vehicle".
The short answer is that the car is protecting the battery when it is fully charged, or when the battery can't accept the amount of charge that is being generated at that moment in time, while still maintaining full use and functionality of the braking system. It basically dumps extra energy to the generator which tries to dissipate it as heat and if that is not enough, the generator powers the ICE. See the pictures below. The first two are from the patent and the third is from the document "Electric Powertrain System Desc 3107 :
For reference, I believe that MG1 is the traction motor, MG2 is the generator motor and the engine is the engine. Below are two snippets from the patent explaining what is going on:
...In this system, in an almost fully charged state where the regenerative power cannot be returned to the battery, the drive motor generates heat from the generated power and consumes the power, thereby compensating for insufficient regenerative braking force...
and
...and an engine reverse drive unit (inverter controller) that drives the engine by supplying part of regenerative power outputted from the drive motor to the motor generator. The regenerative controller can continue the regenerative braking even when all the regenerative power cannot be charged into the battery...
Disclaimer: I cannot specifically tie this particular patent to the Clarity, but it all sure adds up. Both the patent and and the Electric power train description are attached. Please feel free to look over and give your take on the information. Lastly if you want to look for patents yourself it is very simple:
Go to: patents.google.com
In the search box type: assignee
Honda Motor Co Ltd)
You can add a keyword in the search if you want. In this case I searched: assignee
Honda Motor Co Ltd) lithium
and
