no reply..?
no reply..?
FYI, if you are wondering what the question is, @alphayash is replying to the referenced post from way back on September 28, 2022 concerning the "Charge door open" message.no reply..?
on the new, 3rd gearbox
Good job, some pretty robust looking plugs.First reduction gear oil change.
UK, 36,400 miles ~= 58500 km
2020 car.
Many thanks goes to Kiwi, as well as to videos of "Random Technicall Stuff - RTS" and "Rob's page for Kona EV, DIY, and more" for all the information provided.
In my case the socket size was 24mm, I did buy 23mm socket mentioned by others just in case as I rented a car ramp and didn't want not to be able to do the job.
I only removed one underside engine cover, unlike "Rob's page" suggested. My under cover was the same as Robs but I found it easy to undo both drain plugs.
In the UK I've used different oil and plugs to the ones mentioned:
- Oil RAVENOL MTF-4 70W Transmission Fluid which has these specs: API GL-4+, Hyundai/Kia 04300-2N100 WDGO-1, Hyundai/Kia 04300-KX1B0. 2x1L, £43 delivered
- Plug Gold Plug AP05S Magnetic Oil Drain Sump Plug AP-05S - M18 x 1.5mm Thread, which is actually 1" socket but 26 mm worked well here. £44 delivered
- 200ml syringe with hose. Would never do it without it, it will be very hard. £6.60 delivered.
Oil was very dark as others have mentioned.
Oil was sent to analysis.
The results are
Would appreciate if someone can comment on these results with some insights.
All in all the job took about 1.5 hours, on a rented car lift.
Thanks for including all the details as that makes it easier for me. I've added your UOA results for iron and aluminium to the graphs I maintain of first-time changes without magnets at 58,500 km. I've posted those and two others individually for clarity as the resolution is reduced on this forum.First reduction gear oil change.
THIRD gearbox? I feel sorry for you, buddy. How many miles did it take to blow up the first two?
Quite a few owners have done early oil changes on their replaced GRUs and the photos consistently show clear but particle-contaminated oil at the first change.--AT WHAT MILEAGE should I change the oil in this new GRU? 300 miles? 500 miles?
--And AFTER WHAT FURTHER MILEAGE should I change it again?
My experience has indicated that this doesn't help. The magnetic plugs are a good thing to have however and few owners have been fortunate enough to have them in place from 'new'. I'm looking forward to hear the results of your oil changes.--WHERE on the outside of the GRU case is the best place to stack my 5 disc magnets to stabilize the internal magnet? And what works to adhere the first magnet to that spot on the case?
My own GRU doesn't have any obvious date marking so I've not thought to collect information of this nature from other owners, even if they had the opportunity to view it. That is a surprisingly old date from what I would have expected, but there's been no evidence so far from anyone that the problem has been fixed so it's not critical.--Does anyone have knowledge of whether any improvements were made in the design and build of the Kona GRU's as of that Nov 15 2023 date?
--If the A refers to a build version, does anyone have knowledge of whether that version included any improvements in the GRU?
It's good to see evidence that the Toyota plug worked despite that it has a weaker magnet than the Votex. My tests indicated that it should work equally well but actual proof is always good. The amount on them is about what I would have expected even though the GRU failed and I don't think they were cleaned.The plugs both had some fine black gooey residue on them, as you can see from the _attached picture_. Even though they had been unscrewed immediately after I requested them, I have no idea how much sludge was on them when they came out -- I bet the mechanic wiped them off before giving them to the service manager to give to me.
The UOA results may only provide such clues under the particle count heading where you would expect a large drop on the second oil change. I haven't been collating that information but to make sense of it we would need lots of data from oil changes at under 1,000 miles.To continue this thread:
So I'll have 3 samples to send off for analysis, and compare with the analysis of original GRU fill at 36006 mi/57946 km:
-- at 49524 mi/79701 km (original GRU, 13518 mi/21755 km since first oil change),
-- at 49899 mi/80305 km (375 mi/604 km on replacement GRU), and
-- at 50673 mi/81550 km (1149 mi/1849 km on replacement GRU).
Then the questions will be:
--Have the iron and aluminum amounts in the 2 oil changes from the replacement GRU shown that most of the wear-in from the gears has been achieved, and is the internal magnet still bashing aluminum off the cage it resides in (assuming that design remains the same)?
--When should I _next_ change the GRU oil?
I applaud your attention to detail, especially in 2024 when no one seems to want to listen and/or simply act upon previously agreed technical details.To continue this thread:
At 375 miles (604 km) I changed the gear reduction unit oil myself, but realized when I got the forward plastic panel off the bottom that the new GRU did _not_ have the magnetic drain and fill plugs installed from the original GRU, as I had requested that they do. However, the new replacement GRU almost certainly came already with fluid and non-magnetic plugs installed, so I can see why the mechanic wouldn't want to replace the plugs, though while it was on the bench and not yet installed, it would have been an easy thing to do, probably not losing any oil!
Frustratingly, I was doing this on a day that the Hyundai dealer's service dept wasn't open, so I couldn't just go and ask them right then if I could have back my magnetic plugs from the original GRU. And it turns out that the Toyota dealer parts counter, which was still open, didn't have those particular magnetic plugs in stock. So I drained the existing oil, saving some for analysis, and put the non-magnetic plugs back in.
I took the _accompanying photo_ of what I hope is the assembly date printed on the replacement GRU case -- 2023.11.15 -- and perhaps the build version of the GRU -- A -- written with a Sharpie on the case following the date. Questions:
Now I'm at 1149 mlles/1849 km since the GRU replacement, and it's time for another oil change, based on KiwiME's much-appreciated recommendations. I'll be doing that tomorrow, Oct 1, if it's a nice day. In the meantime I've retrieved my Toyota magnetic drain and fill plugs back from the original GRU, which was still languishing in the warranty return (or scrap heap) at the Hyundai dealer's, and bought a couple of new crush washers for them. The plugs both had some fine black gooey residue on them, as you can see from the _attached picture_. Even though they had been unscrewed immediately after I requested them, I have no idea how much sludge was on them when they came out -- I bet the mechanic wiped them off before giving them to the service manager to give to me. Only now do I realize that all along, each time, I should have just asked to talk to the mechanic who did the work.
Thanks for your thoughts.
View attachment 23346 View attachment 23347
No, I expect not. The difficulty is coming to understand the issues and not panicking. This is within normal parameters.A number of Kona owners have been reporting SoH recently, perhaps due to the popularity and ease of using Car Scanner. Your numbers don't seem too unusual, including the variation.
There are very few under 90% so far, but that won't last forever.
Not too sure how to intrepret the SoH value. The SoH was down to 91% just before a BMS software update in 2023. The update has recalibrated the BMS and brought back the SoH number to 100%. I drove the car for another 30000km and it was still at 100%.Just a comment about SOH. At 75000 kms Kona is 92.2%. At 68000 it was 90.1%. Seems quite arbitrary. The weather is warmer now and range improved.
