pictsidhe
Started this thread so we can swap notes on SE autocross setup.
I've been autocrossing my SE since September.
It's an absolute hoot. Most courses are very safe. It is possible to hit hard or squishy things, but that usually requires an excess of stupidity. A few courses have areas where I do avoid driving at 11/10ths as I am wary of obstacles should I completely lose it.
My first event, I was showroom stock apart from a bit more air in the tyres.
Next one, I stiffened the rear ARB by 25% by adding extra holes. At some point after that, I obtained falken 215/45-16 RT660s. Then I got some crash hubs to add another -0.5° camber up front.
Sometimes I do fairly well, sometimes less well. Being a relative noob, that's to be expected?
At my best event I raw timed 4 of the 6 street class Porsche's there. 2x Caymans and 2x 911s. Damn, I was smug after that!
My last event I had a fast codriver. I think he made a bigger difference than the tyres did. He sometimes wins the SSC class at local events. No surprise, he smoked me. He didn't catch my usual class nemesis, though. I do learn a lot from ridealongs and seeing how he drove my car was educational and well worth the rubber and being bumped down to 3rd.
I am sticking to street stock class. GS for our SEs. Mods are limited, which is a theoretically a good thing for my wallet.
Today, a honking huge 25mm rear ARB turned up. Almost 10lb worth. Stock one is 3 ½lb, according to realoem I'll check that when I get it off. I'm a little skeptical about it as I was getting good rotation at the last event, though with tyre pressures pretty close. 42F, 38R, hot. But so many people have said a bar is the way forward...
I have been curious about the F56 suspension specs and have found no hard numbers. I was very, very impressed with the lack of bump steer I couldn't measure some months ago.
I reversed one rear wheel onto a ramp earlier.
The wheel in the air dropped an inch, the one on the ramp compressed 3 inches. With a kerb weight spec of 3150lbs and a 54/46 weight split, I came up with:
Spring wheel rate of 180lb/in
ARB wheel rate of 60lb/in.
Rear frequency 94cpm
I calculate my modified stock ARB at 240lb/in.
So, looks like a 50% motion ratio for the ARB.
The 25mm ARB on 'soft' came out at 550lb/in. Hard at 690lb/in. The ICE cars it is usually bolted to have around 2/3 the weight of an SE's fat butt. That was what finally persuaded me to get one. I may investigate sprung links if it is a little much for daily dodging.
This is fairly crude way to get spring rates. I think it should be within +/-10%, though. The ARB numbers being the most sketchy. But good enough to find the ballpark. I'll do the front at some point, too. I'm expecting a wheel spring rate of around 200 there.
If the weather cooperates tomorrow, I'll get the bar on.
