SameGuy
I talk about my diesel smart a lot, I know, but it serves as a good benchmark for a lot of purposes. When I was running it on the stock Conti EcoContact summer tires, I often averaged 3.7 l/100 km (more than 63 miles per US gallon) over the course of the summer; switching to Conti WinterContacts in the same staggered sizes (on steelies though) cost around 0.8 l/100 km (11 mpg). Later I went +1 with larger, stickier UHP summer Yoko s.drives (uniform sized front and back, but staggered offsets) and summer FE only took a small (~0.3 lhk) hit, but switching to a +1 Nokian Hakka R3 setup for winter (uniform tires and steels all around, spacers in the rear) resulted in zero efficiency loss. They may be more expensive to buy, but Nokians are hard to beat in performance, efficiency, and longevity, so they end up cheaper than lesser tires.I went from 17 summers to 16 winters. I lose efficiency. I know supposedly larger rims make if worse but the difference in summer vs winter even in same temps is huge. I haven't tried swapping just tires as I swap rims as well. I assume the winter tires are just that much worse.
