Savagesymbiote86
I was wondering if anyone found a way to change this. I did find the bolt at the bottom but i'm not sure if there's a way up top from the hood & how much to add.
Did you receive a prompt from the MM for this service item? The earliest recommended interval is 3 years or 47,500 miles, under certain conditions. View attachment 12544
The Clarity "transmission" does not shift. It is simply a gear box that connects the traction motor directly to the front wheels. For reverse, the motor simply runs backwards. The only moving parts in the transmission (other than the gears turning) is the wet clutch which can connect the engine directly to the gears that drive the front wheels.Sorry for the late reply, i have a 2012 accord that wasn't shifting right. But as soon as i changed the transmission oil it was buttery smooth. For financial reasons i want to do it on my own, I have a 100 mile round trip commute for my job. Got the car with 42,000 in Feb, as of today it's around 60,000 miles. I don't want the same thing to happen to this car as with my 2012 accord. I don't drive aggressive with either, i'll call my nearest dealer for a quote & i'll let you guys know.
Thanks for suggestion... It sounds like this could work well.I just use a 12 volt pump to pump the fluid out. What you take out you put back
There are a couple of caveats that I feel are worthy of some thought however:
Your method is certainly easy, and should be just fine if you are careful. As a sanity check, make sure that the amount of fluid that you remove (and subsequently add) is reasonably close to the 2.23 Quarts. That gives you confidence that you did indeed get complete drainage.
- You must be sure that the hose goes all the way to the bottom to get complete drainage (perhaps it was easy to tell?)
- Removing the drain plug as an alternative to pumping insures complete drainage AND it allows you to clean any metallic debris from the magnetic plug
- If you just replace the amount that is removed, you are not guaranteed to be at the proper level (it could have been low to start with, and you would just refill it to the same low level), The 'Overfill plug" actually insures you wind up at the correct level.
Personally, I would probably use the drain plug and overfill plug, but I have access to a car lift... Most people do not.
Does anyone have a picture of the check plug where it’s located to see the fluid level after refilling ?
