Some days it just pays to stay off the interwebs.
However, I didn't and ran across someone with a Niro EV on Reddit who was casually asking the Reddit masses for "gearbox bearing numbers" to DIY a repair, as though someone might have this information in their back pocket. Perhaps surprisingly to some I didn't, so did a quick YouTube search for "niro bearing" and found a teardown video of a Niro gearbox in Ukraine titled "
Factory defect or coincidence. Kia Niro EV", noting that the video has English subtitles but the translation is sometimes lacking. The car had developed an intermittent knocking noise at 77,258 km.
There were two interesting discoveries made by the diligent mechanic. The first at
3:20 is that a steel plug on the input shaft tail-end had dropped off and was rattling around in the very narrow space between the nearby bearing and the housing. The soft steel plug is exactly like a freeze plug and is intended to keep gear oil out of the hollow input shaft, which leads to the splined coupling and motor shaft O-ring past that. The loose plug would
undoubtedly produce significant iron and aluminium particles, as if I needed another factory defect to worry about!
The other discovery he made at
8:13 is that the input shaft bearing on the motor side was showing signs of outer raceway spin, the exact issue I expected long ago would happen due to a design deficiency and which might lead to the knocking noise. I'm not clear on whether he addressed that issue but I think he didn't.
When the gearbox was re-assembled he had replaced the input and intermediate shaft ball bearings but left in place the slightly-damaged output shaft tapered rollers due to the lack of parts. The car's owner apparently wanted it back on the road ASAP.
There are good views of the hollow internal magnet but it seems more secure and confined than the example in my Kona. In one scene he lifts up the casing and the magnet drops out with a clunk. He picks it up and after a time casually places it back in its slot.
