Following! Purchased the lighted switch and quick splices off of Amazon. Currently have the VESS simply unplugged.
I imagine one could order the part. if the ordering system is the same you would need a valid VIN for an EU car to get the part.Thanks so much for posting this! I will tackle this project soon. For now I was able to reach into the area behind the bumper and unplug the speaker, but this is way more elegant.
Is there really no way to order the actual switch from a European dealer? If all the wiring is there, one would just need to install the switch, right?
Question about the splice in: The two wires (blue/black and black) from your splice go straight to the switch, right? In the picture they just seem to disappear into the space behind the dash.
I asked my sister in Germany to ask a local Kia dealership if the switch can be purchased. Unfortunately, they will not sell the single VESS switch, only the entire cluster, to the tune of about 200 Euros. Not worth it, so I will go ahead with the splice and button as you described it.I imagine one could order the part. if the ordering system is the same you would need a valid VIN for an EU car to get the part.
YEs the wires go from the splices to the switch.
That makes sense. I naively thought it was the same circuit board and the blank in the US version just needed to be replaced with the proper switch.Each version of the switch cluster has a printed circuit board with surface-mount buttons, so it's more of a "can't" than a "won't"
Sent from my Pixel 3a XL using Tapatalk
Well, thanks for checking, some may find that price too high, others may not, but now we have a numberI asked my sister in Germany to ask a local Kia dealership if the switch can be purchased. Unfortunately, they will not sell the single VESS switch, only the entire cluster, to the tune of about 200 Euros. Not worth it, so I will go ahead with the splice and button as you described it.
So I don't see wiring pinout for that switch, but the idea is you would have ground wired such that the LED is always grounded and the black/blue wire momentarily gets ground when you push the switch, and the pink wire goes to the positive of the LED. The part of the schematic I posted that shows 'VESS UNIT' and CARSH PAD SWITCH shows the same pinout you would use on your switch
OK towards the end of the video. there should be a '+' and '-' on the switch. Ground goes to the minus. Pink [from car] goes to '+' as I think this is the positive of the LED. One of the terminals marked 'NO' should get the blue/black wire and the other gets ground[so a jumper between '-' and one NC contact, the one that does not have the blue/ black on it
I think
Yellow Wire: NC
Blue wire: NO
Black wire: Led
Red wire: Led
Green Wire: Common
NC has no connection in this case. it is not needed
