Yes, that's 75%-65%. If you stay within those range then you get 8000+ full cycles worth of energy. For example, let's say your battery has 100 Wr energy with 100% charge. If you fully drain and fully charge say 100%-0% all the time, you may only get 300 full cycles, which is 100 Whr x 300 = 30 kWr. If you use only 10% and cycle between 75%-65% then you may get 8000 full cycles worth of energy, which is 100 Whr x 8000 = 800 kWr. So it basically means you can ignore cyclic wear, and the remaining thing is calendar wear.
There are tons of research on the battery depth of discharge vs battery life. Basically, you want to avoid higher voltage levels and shallow cycle as much as possible near the middle. Most EVs have a guardband on the upper limit and lower limit to prevent premature wear.
Page 1 has the
@lincomatic &
@MrFixit posted the instructions on how to enable the battery capacity check through adding a custom PID. Or you can download the whole set posted by
@MrFixit on post #44, it's a backup of his setup including all the custom PID for our Clarity. Thanks again to both of those guys!
I think you are supposed to use the "Dashboard" in CarScanner to monitor things.
Here's my setup, captured while pulling into my home from work. I charged to 80% at work this morning, one way is about 10.5 miles. (I use an iPhone so it's kind of hard to get the files off.)
But then you also have to consider his EV miles is 24.5k (at 48.44Ah). Yeah, it is still impressive. I'm curious of @
Eva Farkas's 83k miles pure HV mode.
