KiwiME
Thanks for the vote of confidence. Hyundai's engineers must be on track to understanding the issues by now and they have the advantage of seeing all the evidence and statistics, nevermind having the accountants on their backs.
It remains puzzling as to what exactly causes the ticking noise and what role the motor plays. I find it hard to believe that the motor could flex on what appears to be considerably-strong mounts but it also can't be ruled out, and you'll note the scoring appears at the inner edge of the raceway housing, which could indicate some sort of misalignment. Otherwise, it's entirely possible that the motor changes (if any) were due to them thinking that was the problem. Reports of metal slivers in the confined area between the motor and gearbox need to be explained as well, as does the one case in Poland of a catastrophic gearbox failure a few days after the noise appeared.
The black oil might look bad but I don't think it's harmful to hardened steel gears or bearings. It's much like polishing aluminium with a fine abrasive, the rag turns black. But several cases have reported 'metal' particles in the oil, more of a worry and harder to explain.
But, it's not by chance that Tesla and Chevrolet's Bolt both use a different design in that area. They seemed to have better understood the pitfalls.
