Teej Hillard
Yes mine went from like 353 miles To Like 188 miles to Go I'm Wondering why it went Down after I Filled up Will The HV Go Back up
Ok Thank youGo to dealer for service update. Will correct inaccurate estimates.
Has anyone else seen falsely high HV ranges reported on the Clarity PHEV? After my last fillup of the 7-gallon tank, it reported 464 HV miles; this time it went to 519!
Unfortunately my highway driving is in practice getting more like the 40-45 mpg advertised. The range only changes when the ICE is running, but falls much faster than the distance I drive, proportional to the amount of gas left.
The EV range refers to the projected distance you can travel on battery power alone. In my experience the EV range is calculated from data from past drives and the ambient temperature.The car uses the average mpg of a combination of gas and electric miles to give you the EV range.
If you leave your car in ECON Mode, it will be in ECON Mode when you start it up. If you leave your car in NORMAL Mode, it will be in NORMAL Mode when you start it up. However, if you leave your car in SPORT Mode, it will be in NORMAL Mode when you start it up.P.S. Econ mode is what your car is in when you first start it up.
