Why does my OEM Clarity cord not work for Volt?
  • Thread starter Thread starter MPower
  • Replies Replies 4
  • Views Views 1K
MPower
My cousins are visiting with their Volt. Last time they were here they were able to charge with the OEM cord from my 2012 Prius Plugin. This time when we plugged in using the Clarity ONE cord, there was an amber light instead of the green light that indicates charging. We had to unplug the cord from the wall to make the amber light go away.
We unplugged the Volt and later plugged in my Clarity again and all was fine. The green light came on.
Why can't the Voltn use the Clarity cord?
My girlfriend has the MY12 Volt, where the EVSE dictates the charge rate; however, I do believe GM altered the software when they did away with the orange cord EVSE so the car could accept 8A 120V.
From our experience, the EVSE's can be used across the vehicles without issue.
The 2013 through 2014 I know defaulted to 8A. You had to go into the charging setup and select 12A each time it was charged. The 2015 through 2018 may also be set up like that, I don't know. This could be the problem though...
