JyChevyVolt
Found a new route. A new record.
BTW, just to get this out there, my 2013 Leaf does give me the option to charge to 80%. I've never used that option personally, but it is there. I kept reading that Nissan doesn't have any option besides 100% so I wanted to set that straight.
Yes, which IMHO is why people should take car to make sure any BEV they buy has a range significantly higher than their anticipated daily driving needs. If you have a 200 mile BEV, then only charging to 80% will get you more distance than if you have an 85 mile BEV and you charge to what the car's BMS tells you is 100%, which is more likely somewhere around 90-96%. If you have only a single car and are worried about having to make an unexpected long-range emergency trip, then that single car shouldn't be a BEV; it should be a PHEV or a gasmobile. Many EV owners have two cars, with the other car being a gasmobile, which they can use for those rare emergency journeys.
One size does not fit all. There is theory and there is practice. I've detailed the theory of what will maximize battery life; what you do in practice will have to fit your individual practical needs, not the theory.
I'm an EV advocate, but that doesn't mean I'm going to ignore the reality that at the current state of development, BEVs are not for everyone. The car anyone chooses has to fit their lifestyle, not some ideal.
Maybe they killed the feature because they realized there are a lot of owners like me that have never used it and have no intention to. EV cars are already range limited. Why would I want to limit it even more? Sure, most days we could get by with setting it to 80% but always having the immediate option to go farther is more important to me.Yes, the option was eliminated in the 2014 model year Leaf, and so far as I know still isn't there.
This was widely reported at the time; for example, in this Green Car reports article.
Anecdotal for sure, but we have a 2014 spark EV, and Subaru Impreza 5-door. We are now a averaging far fewer miles on the ICE, then we have, because we trade off and take the Spark EV for most errands or commuting. Prior to having the Spark we were probably averaging about 10k miles/yr on the Subaru, and 10k miles/yr on our old ICE that the Spark replaced. Have had the Spark EV for 9months and it already has over 10k added to the odometer.So then, you meant "efficient" in the sense of using more of the stored energy to actually send the car down the road, when comparing BEVs to PHEVs?
Well in general I agree with what I think you are saying, which is that BEVs are more efficient in using energy to push the car down the road than are PHEVs. As you say, PHEVs have to be designed to operate both as gasmobiles and as pure EVs. And just as with anything else, something designed to do two different things probably won't do either as well as something designed to do just one thing. All engineering is a compromise, but some compromises are worse (or less efficient in various ways) than others.
But there is one thing running counter to that, and it's this: BEV drivers worry a lot about range anxiety. Or at least, they have to spend some time planning ahead so they can avoid that as much as possible. And that means that a BEV driver is going to take care to ensure he will wind up at the end of the day with some safety margin of range left in the car. If he thinks he won't be able to do that, then he -- or rather many BEV drivers but not necessarily any individual one -- will drive his other car that day, and that car is likely to be a gasmobile.
I wish we could get statistics showing electric-powered miles vs gas/diesel-powered miles on the basis of drivers, rather than cars. A PHEV driver never needs to switch from his PEV to a gasmobile, since his PEV can switch from one mode to the other. Just how many gas-powered miles are BEV owners putting miles on their gasmobiles because they want to avoid range anxiety from driving a BEV that day?
Our situation is similar. We either combine trips or share the Clarity. 95% of the time we use the Clarity while the 4Runner sits parked. The only times the 4Runner is used is to tow the boat (6 warm months only), or when it can't be avoided. Our ICE miles are very few.Anecdotal for sure, but we have a 2014 spark EV, and Subaru Impreza 5-door. We are now a averaging far fewer miles on the ICE, then we have, because we trade off and take the Spark EV for most errands or commuting. Prior to having the Spark we were probably averaging about 10k miles/yr on the Subaru, and 10k miles/yr on our old ICE that the Spark replaced. Have had the Spark EV for 9months and it already has over 10k added to the odometer.
Yes, we sometimes trade so that the person that may have a long trip outside comfort zone for the Spark EV takes the Subaru, but those trips are pretty rare. We are fortunate also, that most places we want to go in the Spark has some charging available nearby.
Despite the hype about the Bolt and Model 3, There aren’t really any truly affordable 200+mile range EVs available. So it is not as simple as just telling people to go buy a car with enough range so that they can do the 80/30 charging rule.
My point is more that if EV advocates are pushing that theory, than the average consumer is not going to want to hassle and will have another reason never to buy an EV.
Still, what harm does it do them to keep the menu option available to people who want to use it? It seems like it takes more work on their part to remove it at that point.
One thing I've noticed with the Clarity, and it was a similar thing with my Sonata PHEV, is once the battery is fully charged, the charger never comes back on again. I believe we've touched on this before. We were driving the Tesla for several days as the weather turned nicer here, so the Clarity just sat for a few days. Not once did it recharge on its own after the initial full charge.
It's hard to believe that no charge is lost as the car sits there for days. So it seems that either the car won't restart it's charging cycle once its full, or the threshold for a new charge cycle is greater than the range I've lost with the car just sitting there.
And yet the range loss on my Tesla can be easily seen day by day. I lose 2-4 miles/day in my cold garage. The Tesla automatically kicks in a new charging cycle once I've lost about 8-10 miles of range. So it would be a head-scratcher to me why the Tesla battery would be so much more prone to range loss than the Clarity's battery.I remember that, and it is a good and helpful anecdotal observation, but does that mean the Clarity will not do anything while plugged in, if either the high voltage or 12V battery dips below some point? BTW, I leave the Clarity plugged in most all of the time, and I have never seen any significant power draw (on the charge point graph) other than for a single charge, or remote climate operation, or sitting in the car with the seat warmer on, so you may be right.
Also, in the Volt, there were occasions (both Gen 1 and Gen 2) where I did not drive them for several days to a week, and I never saw as much as a bar or single mile of range decrease. Self discharge, while likely present at some level, may just be too small over days or a week to start a new charge cycle.
Just like the technical data we eventually got (thanks to jdonalds) on the details of when remote climate comes on, probably there are Honda tech notes on this subject too.
The more curious me would be tempted to at least try to draw down the 12V battery charge level somewhat, to see if it forces a charge cycle to begin, but not sure I can deal with that sort of experiment right now.
I suppose an argument could be made that there's a whole lot more of 'listening' electronics to drain the battery, but still, this is a big difference.
Yes, I was talking about the Clarity PHEV. My point was more in the direction of at what point, if any, does recharging begin without any manual intervention. Let's assume you've lost 10% of the charge while the car is sitting idle for a week or two. I'm sure as the car sits there, the Lithium Ion battery will lose some charge, as they all do. Will the charger automatically kick in once again, or is the initial charge all the car will ever see unless the charge is manually reactivated? Is there any threshold beyond which the charge will automatically kick in again as it does in a Tesla?I don't find this surprising. In previous years it was commonplace to see advice given to BEV owners to not charge the car if it was above the 80% charge threshold. Leaving the battery pack charged to 100% on a long-term basis is bad for battery life... even if that "100%" is really more like 92-96% of the nameplate capacity for the battery cells. So it certainly makes sense for the pack's BMS to report "no charge needed" even if it has lost a few percent.
I presume you're actually talking about the Clarity PHEV here, rather than the Clarity Electric (BEV), but the lithium-ion batteries used in PHEVs are not that different from the ones used in BEVs.
Would temperature also need to be recorded and somehow factored in (certainly for milage, but what about just kWh)?
