JyChevyVolt
Ouch. That sucks. I like to see your Fall, Spring stats. Looks like you don't get that much regeneration.
I've read enough on that subject to know that it's very, very difficult to measure the exact charge level of a li-ion battery pack. That's a challenge even for someone specializing in EV/battery cell electrical engineering. On the other hand, measuring how much energy is fed into the charger in the car is dead easy; all you need is the right meter between the wall plug and the car.
I love when the temp warms up. I don't usually do as well as you are showing there, but much better than the winter. All the cold air slid off the arctic down to the midwest. I am fine if it goes back nowOuch. That sucks.
Yeah, I've seen the kWh use go backwards on long regeneration. On top of the hill, it will show 9.8kWh and then 9.6kWh on the bottom of the hill.Usually you integrate the current to and from the battery. Coulomb counting. The display in my and Jy Volt is an estimate used during operation, not from the wall. However, the Gen 2 Volt will report MPGe, which is always from the wall.
I love when the temp warms up. I don't usually do as well as you are showing there, but much better than the winter. All the cold air slid off the arctic down to the midwest. I am fine if it goes back now![]()
1. 8 mile local (45 mph) EVNice, pretty good efficiency. This must be at highway speeds?
PHEVs use a lower percentage of the battery to prevent damage from over-voltage while the generator is running. BEVs don't have this issue.
The design goals are very different for a BEV and PHEV. A BEV might only need to last 500 to 1000 cycles to go a few hundred K, but a PHEV might need 5000 cycles to do the same.
Unless you live in a hot climate, and want to remote start the cabin conditioning to cool it off.That's actually a good point and a good reason to plug it in. In the summer, not so much.
1. Is this the Clarity Electric (BEV), or the Clarity PHEV?
1a: If it's the PHEV, then likely there's no good reason to leave it on the charger all the time. The PHEV doesn't have a built-in battery heater, so that won't keep the battery warm even if you do leave it plugged in all the time.
1b: If it's the BEV, then you are advised to keep it plugged in at night anytime the outside temperature is going to drop below freezing, so the car can run the battery heater as necessary to keep it warm.
2. Generally speaking, you shouldn't be charging any BEV to 100% on a daily basis; that's bad for battery life. The usual advice is to charge it to 80%, unless you need to maximize the car's range the next day. If you want to get down into the weeds (WARNING: What follows is very definitely "inside EV engineering", so skip the rest of this paragraph unless you're a STEM geek like me) of doing everything you can to maximize battery life, then you should be selecting a charge level balanced around a 50% SoC (State of Charge). That is, you should select a charge level that will allow your car to start the day as far above 50% as it will end it below 50%. (For example, if your daily drive uses 40% of the battery's capacity, then you should charge to 70% and discharge to 30% by the end of the day.)
Unfortunately, according to some recent discussion here on this forum, it appears not all BEVs are built to allow the driver to select the charge level. I know the Tesla Model S allows you to select whatever level of charge you want; I'm told the Leaf gives you no control at all (another reason to avoid buying a Leaf!); I dunno about the Clarity Electric.
There are other issues related to this topic. If you're going to leave a BEV sitting for a month or longer, then ideally you should discharge the pack to 50% but leave it on the charger. That's possible in Tesla's cars, but I dunno about other BEVs. I find it shocking that not all production BEVs allow you multiple options on setting the level of charge, but apparently that's the case.
That's never stopped me (talking beyond the edges of what I understand)......dstrauss, I realize I have not fully answered your question. But I tend to get myself into trouble when I start talking beyond the edges of what I really understand, so I think I've said about as much on this subject as I should. Perhaps others can expand on the differences in engineering between li-ion battery packs in consumer electronics vs. plug-in EVs.
For the short range EVs, only charging to 80% and discharge to 30% means having a very limited range and no buffer if you have unexpected travel needs.
I would think a PHEV's battery pack is going to be inherently less efficient than a BEV because of it's split personality - think of the PHEV as Dr. Jekyll and Mr. Hyde...
We have 2 Electric cars so we shuffle the charging cord between them. Our KIA SOUL EV can sit a week and not lose any charge. Our 2012 Tesla S 85 will use phantom power and drop 5 or 10 miles in a day. We only charge to 80% most for the time since it still shows over 200 mile range. Even if we were away for 2 weeks they don't need to sit plugged in.
@Pushmi-Pullyu - Sorry for my lax use of "efficient" - I am thinking in a more global sense of the useful capacity in EV mode between a BEV and an PHEV, as teh PHEV has to maintain a reserve for hybrid mode driving beyond the EV limits.
The older leaf had the 80% option. The newer leaf don't. Manufacturers can increase the EPA range by eliminating the 80% option. The Bolt EV uses hilltop reserve to get around this issue.BTW, just to get this out there, my 2013 Leaf does give me the option to charge to 80%. I've never used that option personally, but it is there. I kept reading that Nissan doesn't have any option besides 100% so I wanted to set that straight.
